Peng's Grey Caddy
Peng
Re: Peng's Grey Caddy
Post by Peng » Fri Oct 16, 2020 8:43 am
Having a look at fitting these seats, havent got round to it as been away etc. Little metal tab on the end is causing me some grief. Any ideas? Would touran bases solve this completely?Image
Robert24
Post by Robert24 » Fri Oct 16, 2020 10:52 am
Good morning,
With mine , I cut them off and drilled original bases (there's a how to on here somewhere)
Hope this is of help
Robert
Peng
Post by Peng » Fri Oct 16, 2020 10:59 am
Yeah I tried a look but hard with so many seat topics ok so just cut them off, I thought about that originally but didn't know if it would cause issues
Robert24
Post by Robert24 » Fri Oct 16, 2020 11:11 am
Hi,
Done this on the sirocco seats approx. 2 years ago never had a problem (used high tensile bolts and large o/d washers just in case there was an issue)
best of luck
Robert
Peng
Post by Peng » Fri Oct 16, 2020 11:13 am
Cheers Robert, will give it a go over the weekend
Robert24
Post by Robert24 » Fri Oct 16, 2020 11:17 am
Hi,
What seats have you got to put in?
just curious
Robert
Peng
Post by Peng » Fri Oct 16, 2020 11:21 am
Picked up a set of VRS seats, loved these when we had the octy vrs ImageImage
Robert24
Post by Robert24 » Fri Oct 16, 2020 11:27 am
cool, 8)
they'll be a definite improvement on the standard seats
Robert
Giddy
Post by Giddy » Fri Oct 16, 2020 11:32 am
These look great. If you using touran, bases there's a little slot for that pin to go in, at the very front of the base. Mine went straight in without cutting off anything.
Instagram: @giddywagen
Peng
Post by Peng » Fri Oct 16, 2020 11:34 am
Ah thats interesting. Thats what I wondered, if touran bases means I would need to make no modifications, I might be better off going for them
Robert24
Post by Robert24 » Fri Oct 16, 2020 11:39 am
hi,
with mine i needed mine sitting a bit lower as i'm a bit of a tall lad and needed to feel like i was sat in the van, not on it if you see what i mean
Robert
Deano334
Post by Deano334 » Fri Oct 16, 2020 1:19 pm
Pukka van mate, Loving those alloys 🤙🏼
Peng
Post by Peng » Sun Oct 18, 2020 4:06 pm
Just fitted in the VRS seats using the touran bases. As said many times before, straight swap in and fit. Really happy with them and they sit lower than the standard seatsImage
Peng
Post by Peng » Mon Oct 19, 2020 10:16 am
I bought this rear light and it didn't work, got a refund from the seller and sent it back but the seller moved address and closed down so it got returned back to me. Does anyone want it for free, just cover postage? Not sure if its any good to anyone or if you could work out how to get it working. If not it'll just go in the bin ImageImage
