Page 3 of 4
Re: Peng's Grey Caddy
Posted: Fri Oct 16, 2020 8:43 am
by Peng
Having a look at fitting these seats, havent got round to it as been away etc. Little metal tab on the end is causing me some grief. Any ideas? Would touran bases solve this completely?
Posted: Fri Oct 16, 2020 10:52 am
by Robert24
Good morning,
With mine , I cut them off and drilled original bases (there's a how to on here somewhere)
Hope this is of help
Robert
Posted: Fri Oct 16, 2020 10:59 am
by Peng
Yeah I tried a look but hard with so many seat topics
ok so just cut them off, I thought about that originally but didn't know if it would cause issues
Posted: Fri Oct 16, 2020 11:11 am
by Robert24
Hi,
Done this on the sirocco seats approx. 2 years ago never had a problem (used high tensile bolts and large o/d washers just in case there was an issue)
best of luck
Robert
Posted: Fri Oct 16, 2020 11:13 am
by Peng
Cheers Robert, will give it a go over the weekend
Posted: Fri Oct 16, 2020 11:17 am
by Robert24
Hi,
What seats have you got to put in?
just curious
Robert
Posted: Fri Oct 16, 2020 11:21 am
by Peng
Picked up a set of VRS seats, loved these when we had the octy vrs
Posted: Fri Oct 16, 2020 11:27 am
by Robert24
cool,
they'll be a definite improvement on the standard seats
Robert
Posted: Fri Oct 16, 2020 11:32 am
by Giddy
These look great. If you using touran, bases there's a little slot for that pin to go in, at the very front of the base. Mine went straight in without cutting off anything.
Posted: Fri Oct 16, 2020 11:34 am
by Peng
Ah thats interesting. Thats what I wondered, if touran bases means I would need to make no modifications, I might be better off going for them
Posted: Fri Oct 16, 2020 11:39 am
by Robert24
hi,
with mine i needed mine sitting a bit lower as i'm a bit of a tall lad and needed to feel like i was sat in the van, not on it if you see what i mean
Robert
Posted: Fri Oct 16, 2020 1:19 pm
by Deano334
Pukka van mate, Loving those alloys
Posted: Sun Oct 18, 2020 4:06 pm
by Peng
Just fitted in the VRS seats using the touran bases. As said many times before, straight swap in and fit. Really happy with them and they sit lower than the standard seats
Posted: Mon Oct 19, 2020 10:16 am
by Peng
I bought this rear light and it didn't work, got a refund from the seller and sent it back but the seller moved address and closed down so it got returned back to me. Does anyone want it for free, just cover postage? Not sure if its any good to anyone or if you could work out how to get it working. If not it'll just go in the bin
Posted: Sun May 09, 2021 11:26 am
by Peng
Wow, Holy thread revival!
Little mishap today, control arm from arm sheared off from the strut on the front. Hoping I can get it tacked back on, if not I guess I best start looking for new struts!
