My Caddy Conversion....
Tum-yeto
Post by Tum-yeto » Mon Sep 28, 2020 11:07 pm
Though I’d start a thread for the conversion of my Caddy.
Don’t have a huge amount of pics of before internally but I’ll start documenting it a bit better Image
Came full height ply lined, thick (badly) carpeted lining, zero sound deadening and insulation and some shoddy roof and floor lining.
I’ve stripped it all out and ordered a load of stuff to start the conversion.
What it looked like before (ish)
One side removed, wheel arch ply and carpet.
Other side, will remove that OEM panel when I can be bothered dealing with those horrible pop fastener things.
Getting there, closed the side door and found more that I forgot about! Image
Tum-yeto
Re: My Caddy Conversion....
Post by Tum-yeto » Wed Sep 30, 2020 5:17 pm
So came home from work to a load of packages. Insulation coming out my ears! Image
Noico sound deadening sheets, Kiravans foil backed foam sound insulation, dodo deadmat duo flooring and a roll of fluffy dodo thermo fleece.
Best get stripping and cleaning!
Tum-yeto
Post by Tum-yeto » Thu Oct 01, 2020 10:39 pm
Stripped the remainder of the rear, headliner, bulkhead, OEM panels and then cleaned the hell out of it.
Amazing what some soapy water can do.
Rigguz
Post by Rigguz » Thu Oct 01, 2020 11:29 pm
Good work!! Interested to follow this thread, as it’s one of the next jobs on my list!! Where did you buy all of the insulation / sound deadening from?
Tum-yeto
Post by Tum-yeto » Thu Oct 01, 2020 11:36 pm
[mention]Rigguz [/mention]cheers dude!
The sound deadening was from Amazon I think, it’s the Noico stuff. The foil backed foam was from Kiravans, the dodo deadmat and thermo fleece was from deadening.co.uk
All super quick delivery too!
Giddy
Post by Giddy » Fri Oct 02, 2020 7:44 am
Good start, this will keep you busy for at least few days.
Looks like a double maxi in that fiseye lens photo :D :D
Instagram: @giddywagen
Caddy 4, Highline, 1.4 TSI, Build thread https://www.caddy2k.com/forum/viewtopic ... 13&t=37368
Tum-yeto
Post by Tum-yeto » Sun Oct 18, 2020 11:09 am
Been a week or so, trying to fit this in between a full time job and running a bike repair business in my spare time. So very slow progress. So enjoyable though!
Sound deadening completed, every visible bit of outer skin covered with it. Bit OTT but I had extra.
Foil backed insulation from Kiravans fitted over the top of all that now too. The difference in sound is amazing!
Fitted the 100mm thermo fleece from Dodomat but didn’t get any pics.
Carpet arrived and tested a panel. Hidden clips make it look super clean!
Now to attempt the rest of the ply panels, cut some ply to fit in the cavities then carpet the sides ImageImage
Has anyone got any pics of the rear tailgate carpeted? Not sure what to do here, just carpet the ply panel or carpet up to the seals?
Swifty
Post by Swifty » Tue Oct 20, 2020 9:22 am
Looks fantastic! This is deffo gonna be my first serious mod on my new Caddy when I find some spare time. I'm finding the noise is the biggest drawback to Caddy life so far.
