My mk3 for motorcycle use
apriliajimmy
Post by apriliajimmy »
Here is my mk3 caddy I am going to be using for my motorcycles and cycling. Image
Sent from my WAS-LX1A using Tapatalk
apriliajimmy
Re: My mk3 for motorcycle use
The next thing I want to do it carpet the rear. Then sort out something better inside to hold my motorcycles and cycles up. Image
apriliajimmy
Getting ready to carpet the back of the van. Image
apriliajimmy
I'm going to carpet the ply lining I already have. I did think of doing it without the carpet lining. Image
apriliajimmy
I added some vibe 6x9s. I have had the speakers for over 10 years Image
apriliajimmy
I covered the head lining in flux leather and added some cheap lights off ebay.
I just need to think of where to add the switches for them. Image
apriliajimmy
I put sound deadening on the arches and put carpet over them Image
apriliajimmy
I used some rubber mat off ebay for the floor. It's not stuck on or anything. Same with the ply on the floor. Image
apriliajimmy
The led lights are flush fit and were very cheap £11 for 6 Image
apriliajimmy
I bought a xtrons stereo so decided to fit a reversing camera. The one I had was a bit bulky so I bought a smaller one and cut a hole in the rear door handle panel. Image
apriliajimmy
apriliajimmy wrote:I bought a xtrons stereo so decided to fit a reversing camera. The one I had was a bit bulky so I bought a smaller one and cut a hole in the rear door handle panel. Image
I will have to get a better picture once fitted properly
apriliajimmy
I put the reversing camera wire though the door loom. I had it just taped to the door to start with. Image
apriliajimmy
The xtrons stereo is good for the price it can be a bit buggy with the radio names when the signal is low. I would like a better aerial or something the caddy one is really badImage
apriliajimmy
I painted my side strips. They had a slight bend in them so the mini seat is there to help it stay. I ened up using so better 3m tape. scotch 3m tape is really strong and is 0.6mm all the other brands are 0.8 to 1mm. Image
apriliajimmy
I bought this switch panel for the back of the van. I might not use it and get something smaller. Image
