I bought the cheapest running Caddy I could find .
Zeberdeecaddy
Re: I bought the cheapest running Caddy I could find .
Post by Zeberdeecaddy »
Thanks .
It looks a lot better in pictures than when you’re stood next to it .
But it’s a 200k van & looks presentable enough .
‘08 White Caddy .
Static low on 18 inch steels .
ELVIS
Post by ELVIS »
Matchy wrote: Sat May 01, 2021 11:24 pm What size tyres are you running? Cheers
That looks perfect. I love steels over alloys.
15s or 16s?
Zeberdeecaddy
8x18 ET45 .
I like the steels , in keeping with the basic van .
‘08 White Caddy .
Zeberdeecaddy
Fitted my bulk head grill covers , as recommended by @CADDY Lux , definitely take some of the ‘boom’ out of the cabin .
Was having trouble starting it once hot , replaced the coolant temp switch & it now seems ok again .
I need to drop the fuel tank at some point as i can only run it down to half way on the gauge before it runs out of fuel . There’s definitely still half a tank of fuel still in there .
Got to use it properly for the first time yesterday .
100 mile round trip to go mountain biking .
It cut out on the way home , loads of Black smoke out the back , cooling fans running on full .
Left if for a couple of minutes & re started fine , so not sure what happened there ??
‘08 White Caddy .
Zeberdeecaddy
‘08 White Caddy .
Zeberdeecaddy
‘08 White Caddy .
Celticrsmith
Post by Celticrsmith »
👌 lovely
Zeberdeecaddy
Cheers .
Strangely enjoying having a basic daily .
‘08 White Caddy .
TK2192
Post by TK2192 »
Looking mega in the last pic!
Zeberdeecaddy
Thanks .
Still working through a few issues , but it’s now looking like I hoped it would .
‘08 White Caddy .
Cuddlycaddy
Post by Cuddlycaddy »
Loving this so far mate
Zeberdeecaddy
Cheers .
Managed to sort the ‘running out of fuel at half full’ issue .
Removed the fuel tank* & found someone had fitted the feed & return lines the wrong way round .
So the pump was feeding up the return & the feed was only half in the tank .
Surprisingly starts much better now .
* well got the fuel tank as low as I could , having flipped the axle & doing this on the driveway there’s no way the tank was ever coming fully out .
Managed to spill quite a bit of diesel over myself & the driveway when removing the pump .
‘08 White Caddy .
Exuptoy
Post by Exuptoy »
That looks perfect!
What lowering kit did you fit?
Zeberdeecaddy
Thanks 👍
I originally had a pro sport kit fitted .
Axle fip on original shackles & wound right down with hub mod on the front .
Was never really happy with them , seemed too soft .
Now running MK5 Stance plus ultra’s with the helpers removed on the front . Sits at the same height , but much improved ride .
I really need to hub mod it to get the helper springs back in .
Ordered some Gaz short shocks for the rear 8 weeks ago , but think there still a good few weeks from being delivered .
‘08 White Caddy .
CADDY Lux
Post by CADDY Lux »
Zeberdeecaddy wrote:Fitted my bulk head grill covers , as recommended by @CADDY Lux , definitely take some of the ‘boom’ out of the cabin .
Good work there dude. Told you they are the best mod out there hehe. ImageImageImage
Reason: removed irrelevant part of the quote
