My caddy maxi build thread
Aronfields
Post by Aronfields » Mon Mar 08, 2021 10:48 pm
So yesterday I picked up a 2009 caddy maxi, 2.0 tdi 6 speed with 110k
Got it home and replaced clutch and flywheel with new luk items, and a full service
3 stage polish will be carried out tomorrow and then on Wednesday will have a couple of parking dents removed
Aronfields
Re: My caddy maxi build thread
Post by Aronfields » Mon Mar 08, 2021 10:51 pm
Plans are to remove the tow bar and paint the rear bumper, seats changed, multi function steering wheel, upgrade cluster, cruise control. Touran door cards.
Remap egr and dpf removal.
Aronfields
Post by Aronfields » Mon Mar 08, 2021 10:54 pm
I will also fit coilovers and rear axle flip. Wheels and front end conversion along im not 100% sold on it.
The rear will be insulated and covered in 4 way stretch carpet
I do car/truck keys for a living and this will be my daily work horse
Aronfields
Post by Aronfields » Wed Mar 10, 2021 10:49 pm
Today I got some free time, stripped out the rear and cleaned, insulated and started to cover with 4 way stretch
Aronfields
Post by Aronfields » Wed Mar 10, 2021 10:51 pm
Oh and a new floor
Aronfields
Post by Aronfields » Wed Mar 10, 2021 10:53 pm
Aronfields
Post by Aronfields » Wed Mar 10, 2021 10:54 pm
Aronfields
Post by Aronfields » Wed Mar 10, 2021 10:58 pm
Still parts to finish carpeting bulkhead and exposed metal, I had my last van insulated in the same stuff and the difference it makes is un believable.
Going to weld up a steel frame tomorrow to hold my organisers so the dont rattle then once the linings and electrics are finished fit the frame and a bench
Vag wag
Post by Vag wag » Thu Mar 11, 2021 8:20 am
Good work a great improvement... 8)
Aronfields
Post by Aronfields » Thu Mar 11, 2021 5:50 pm
Got the rest finished, wired and 90% fitted out,
Aronfields
Post by Aronfields » Thu Mar 11, 2021 5:51 pm
Aronfields
Post by Aronfields » Thu Mar 11, 2021 5:52 pm
Aronfields
Post by Aronfields » Thu Mar 11, 2021 5:54 pm
The rubber floor looks like it's going to be a nightmare to keep clean, still to tidy up a bit of wiring and fit another key cutter, then I can move on to the exterior, dont know how it's going to work out because the head room I've lost is hugh in the back I have to half crouch to sit at the bench but I love to way it drives so might have to be a bit uncomfortable to I can afford a new transporter
Aronfields
Post by Aronfields » Fri Mar 12, 2021 9:05 pm
Got some pasdat cc heated leather seats for free today, but like look twisted and I'm.not sure if they will definitely fit but time will tell they need a good clean as the car they came from have had not front doors on them for the last month, anyways I then started into the paint work
Aronfields
Post by Aronfields » Fri Mar 12, 2021 9:07 pm
