NZ 1.2TSi Build
Labern
NZ 1.2TSi Build
Post by Labern » Tue Mar 16, 2021 9:14 pm
Here is my Caddy Just after picking it up.Image
Sent from my SM-A505GN using Tapatalk
Scoobysrt
Re: NZ 1@.2TSi Build
Post by Scoobysrt » Tue Mar 16, 2021 9:46 pm
Nice colour and picture 8)
Labern
Post by Labern » Wed Mar 17, 2021 12:48 am
Thanks.
Just installed Touran Carpet and seatsImageImageImage
Russ74
Post by Russ74 » Wed Mar 17, 2021 8:35 am
Hi
Go to Harry’s Euro they based in NZ.
They will be lowering a caddy next week if you can pop around.
Labern
Post by Labern » Wed Mar 17, 2021 10:50 am
Yeah I have been there a few times to get parts. I just got a rear wiper delete from then the other day. I have just lowered my caddy. Haven't taken a pic yet to post.
Labern
Post by Labern » Wed Mar 17, 2021 10:54 am
Got myself some cheap second hand 18" mags and tyres. The offset makes the stick out a bit but I think if I change the tyre later from 235 to 215 it should be better. The rear door just touches. Image
Labern
Post by Labern » Mon Mar 22, 2021 8:35 am
Lowered my caddy using dark side developments shackles and eibach 60mm lowering springs.
It didn't lower the front 60mm, more like 40 - 50mm. I think this is because I have the 1.2tsi which will be lighter then some of the bigger engines.
I had to out the shackles in the 50mm position to make it look more even but the back sits slightly lower the the front. Image
Labern
Post by Labern » Mon Mar 22, 2021 10:17 am
Installed a 4G Android 10 Joying headunit today.
I have used Joying headunits before and was happy with it and this newer version is really nice.
I have a reverse camera and oem microphone on order which I will install when they arrive.
Now I just need a Multifunction steering wheel to match.
Labern
Re: NZ 1.2TSi Build
Post by Labern » Sun Mar 28, 2021 3:11 am
Changed the interior light so I could install the microphone for my new head unit. Also gives me reading lights which is a bonus.
Just need to swap out lamps with Leds at some point.Image
Labern
Re: NZ 1.2TSi Build
Post by Labern » Wed Apr 07, 2021 10:21 am
Today I installed S3 air vents. Someone else had played around with one of the original ones and it was stuck to the inner duct so was difficult to get out.
I printed my own adapters as having them shipped from UK is rather expensive and well I have a 3D printer so why not.
Very happy with the result. Looks much nicer.Image
thecolourpurple
Re: NZ 1.2TSi Build
Post by thecolourpurple » Wed Apr 07, 2021 7:35 pm
Some good work being done there at the planets edge. It's great to see Caddy's being modified no matter what the location. Keep up the good work
Labern
Re: NZ 1.2TSi Build
Post by Labern » Wed Apr 07, 2021 10:51 pm
thecolourpurple wrote:Some good work being done there at the planets edge. It's great to see Caddy's being modified no matter what the location. Keep up the good workImage
Thanks.
I plan to do a lot more with it. The problem is getting the parts. I have been in contact with a few companies in the UK but they don't want to ship to NZ.
Labern
Re: NZ 1.2TSi Build
Post by Labern » Wed Apr 07, 2021 11:56 pm
Just had the front windows tinted to the legal limit. Looks better in real life then the photo. Rear window was already tinted when I got it so didnt cost much to get done. Image
Labern
Re: NZ 1.2TSi Build
Post by Labern » Thu Apr 08, 2021 12:29 am
Replaced the top rear brake light with a black smoked one. It didnt fit as nice as the original so I removed the smoked lens and put it on the original base. Also the rubber seal is more firm so it make it sit out a bit more. I hope this will squash down over time. Image
Labern
Re: NZ 1.2TSi Build
Post by Labern » Thu Apr 08, 2021 12:45 am
I'm starting to prep the back of my caddy for carpeting. Not 100% sure the approach I will take yet but I found there was a void behind one of the side panels so I laser cut a box to fit in there. Gives a nice small storage space for tie downs or something. I may put some elastic across the front to stop things coming out. Image
