Red MK3 CNG Build
judasfan
Re: Red MK3 CNG Build
Post by judasfan » Sun Apr 04, 2021 3:50 pm
Thanx for the quick response! Could you be so kind to clarify this.....
mk3boy wrote:
Sun Apr 04, 2021 12:42 pm
Have the Stock heater in the Van and no aftermarket or additional heater installed
....as I understand you correctly, you have factory fitted heater in your Caddy?
mk3boy
Engine size/power: 2.0 CNG (107bhp)
Post by mk3boy » Sun Apr 04, 2021 9:41 pm
Yes i have teh Factory fitted heater installed in my Caddy. From my understanding and some short reserch in the service manual and trought the Parts lists there is no Webasto heater installed like it wood be in a disel version of a caddy.
Reason: removed unnecessary quote of entire previous post
judasfan
Post by judasfan » Mon Apr 05, 2021 6:02 am
Yes i have the Factory fitted heater installed in my Caddy.
Again, thank you for your reply! If you don't have Webasto heater of any kind, like pre-heater or auxiliary heater, could you tell me the PR-Code of what you have? Maybe you have the electric PTC heater,which is integrated into the ventilation box? Sorry for the many questions, I am investigating the possibility for retrofitting heater in my CNG Caddy.
mk3boy
Post by mk3boy » Mon Apr 05, 2021 10:13 am
My Van has automatic air conditioning installed. In the ac unit istself is a heater installed Partnumber:
1K0963235F. It shoulb be Nr. 17 in this diagram https://volkswagen.7zap.com/ImgsWaterma ... 820200.png.
There schould be the option of an additional heater from Webasto Partnumber: 1K0815007BK (for petrol engine). Shuld be Nr. 1 in this diagram https://volkswagen.7zap.com/ImgsWaterma ... 819700.png. From all i can see it should be possible to run this part but am absolutly not sure about it.
As far as i can tell, i don´t have it installed in my Caddy.
judasfan
Post by judasfan » Mon Apr 05, 2021 8:09 pm
1K0963235F
Thank you for the detailed answer! So, you got so called "dumb" electric air heater, without CAN communication, which is controlled via relays.
The only way to know for sure if you have additional heater is to make scan, and if you have 18 module present, than you have additional fuel heater.
Reason: combine two replies into one post
mk3boy
Post by mk3boy » Tue Apr 06, 2021 8:05 am
@judasfan Scanned it this morning. I dont have a 18 module present. Therefore i don´t think i have a additional fule heater installed. Sorry but i don´t have any additional information.
judasfan
Post by judasfan » Tue Apr 06, 2021 8:12 am
@mk3boy Hello and thank you for your effort, much appreciated! :) I think that no CNG Caddy was ever factory fitted with Webasto heater! Eventually in the cold northern European regions.
