Caddy Carrera Cup 2,0 Loud as Hell
DjLoop
Post by DjLoop » Sat Jun 19, 2021 1:48 am
Hello Everyone!
I baught this caddy new in 2008 and used it as a work car for 3 years. After the 3 years did pass it all started to go crazy.
The Caddy is a Car Audio Car. Classified for dB Drag, Bassrace, EMMA ESPL, EMMA ESQL.
The car do today. 164,9db and its full drivable.
Fune stuffs to know about the car.
Numbers of OEM windshields raplaced untill today: 38
Number of Bulletproof windshields raplaced untill today: 5
Number of wasted rear tiers due to weight: To many :?
The total weight of the car now with lithium batteries is 2,6t
Top speed of the car is 202km/h
Amount of amplifier power today: 116,000w "116kw"
Amount of Lithium AH: 1200ah "16pcs 300ah winstons cells in a 4S4P config"
Reinforcement 140m + of 40x40x3 steel :)
I will upload pictures like day by day since most of the car is alrdy done and i have built on the car for many years.
If you have any questions feel free to ask!
I Start with some pictures from when the car was OEM or almost OEM and then we go forward with new pictures
Repainted straight from Body shop!
Let the party begin :P
Vw Caddy 2008 Carrera Cup Showcar/Db Drag/Demo car
1200Ah Winston Lifepo4 Lithium
114kw in Amplifier power
140m 40 x 40 Steel reinforcement
Bullet Proof Glass "14mm"
370a Mechman Alternator
8 pot RS6 Calipers
370mm RSQ5 Discs
EGR Delete
PDF Delete
038 130 073AL injectors
Turbo GTB1749V
Full Powerflex
DjLoop
Re: Caddy Carrera Cup 2,0 Loud as Hell
Post by DjLoop » Sun Jun 20, 2021 5:18 pm
First to do was build a steel frame for the enclosure
When you are planing a build like this you need to do correct from the start or it will turn out to be a hell later :P
To be continued!
8 pot RS6 Calipers
370mm RSQ5 Discs
EGR Delete
PDF Delete
Turbo GTB1749V
Full Powerflex
R22LRM
Post by R22LRM » Sun Jun 20, 2021 5:55 pm
Keeping a close eye on this one
R22LRM
Mk5 Tfsi powered
DjLoop
Post by DjLoop » Thu Jun 24, 2021 9:59 am
After lite more steel to cover the window frame comes wood :D
Outher shell is made is 21mm kirch plywood
and then we went for 19mm+12mm mdf
This was done in 2014 :)
8 pot RS6 Calipers
370mm RSQ5 Discs
EGR Delete
PDF Delete
Turbo GTB1749V
Full Powerflex
R22LRM
Post by R22LRM » Thu Jul 01, 2021 9:59 am
Great work
R22LRM
Mk5 Tfsi powered
DjLoop
Post by DjLoop » Fri Jul 02, 2021 6:08 pm
Here we did start with the enclosure etc. This first build was done together with Massive Audio. And later we changed some stuffs and did put DD Audio "Digital Designs" inside instead of the Massive Audio stuffs.
Hope you Enjoy!
8 pot RS6 Calipers
370mm RSQ5 Discs
EGR Delete
PDF Delete
Turbo GTB1749V
Full Powerflex
DjLoop
Post by DjLoop » Fri Jul 02, 2021 6:11 pm
After we had been using and driving the car for a while the rear leaf did not manage the weight. So i made new rear leaf with dubble blades and added Firestone airbags that manage 1400kg/each . We also did put a new rear axel to ensure safety
8 pot RS6 Calipers
370mm RSQ5 Discs
EGR Delete
PDF Delete
Turbo GTB1749V
Full Powerflex
DjLoop
Post by DjLoop » Sun Jul 04, 2021 11:59 am
After some issues with the 6th ordered full blowout enclosure ended upp the baffles did crack.. So a new box was in place.
This time we built a 4th oredered clampshell qirh 8pcs Digital Designs DD9515SC
The baffles this time was made of 3x10mm MDF + 2x12mm Kirch Plywood "10mm mdf in middle followed of kirch plywood on both sides and then another mdf on outside as sandwich"
8 pot RS6 Calipers
370mm RSQ5 Discs
EGR Delete
PDF Delete
Turbo GTB1749V
Full Powerflex
DjLoop
Post by DjLoop » Sun Jul 04, 2021 12:01 pm
After a while the we changed also the dorrs and rebuilt them for 3x8" midwoofers and 1x tweeter tuned 75hz
Midwoofers 3x Faital Pro 8PR200
Tweeter 1x Faital Pro FD371
Later on we changed for Digital Designs midwoofers and also added some grills
8 pot RS6 Calipers
370mm RSQ5 Discs
EGR Delete
PDF Delete
Turbo GTB1749V
Full Powerflex
DjLoop
Post by DjLoop » Mon Jul 05, 2021 9:49 pm
Everyone that has put some subwoofers in their caddys i think by this time know that the roof is a very weak spot on our Caddys.
After many 160db+ rounds my roof cracked really bad and had to be rebuilt completely. The Frame separeted and the cracks was everywhere.
After alot of welding before in the caddy we mentioned that the cracks everytime started from where we had been welding before so this time we took some caddy sheets to a friend that do alot of welding tests so we tested alot of different technique and find out that the outside shell of caddy has a special steel that is thin and very hard wich cause it to crack easy and lose alot of strength.
The best technique that we come up to was Spot welding. So we did spotweld regular steel sheets 3mm thick to the OEM body sheets so to build area so we later could work with MIG/MAG machine.
Said and done. A spot welding machine was baught and the work could start.
But... The parts on the roof was so bad so first we had to find some new roof parts.. So i baught the cheapest caddy that i could find with broken engine and..
A super old europei 11 was leaking alot of water but did the job super good!
Here you can also se we have built a new enclosure but picture on this will come up later!
8 pot RS6 Calipers
370mm RSQ5 Discs
EGR Delete
PDF Delete
Turbo GTB1749V
Full Powerflex
DjLoop
Post by DjLoop » Thu Jul 15, 2021 12:29 am
Time for new pictures but this time i will upload some photos that is from today :)
During the winter to 2021 we started to rebuild the car to a 2019 and we have come up with some issues. Hope someone here can help i has been seraching for some houers now without any information.
When we just plug them in to 2008 loom they flimer when rise rpm and P-lights do not work.
If we plug in 2019 halogen lights all works same as 2008.
If anyone know where to find information of how to wirre 2018 led lights to 2008 halogen please help me!
Lights to fit:
Halogen lights that works
The car right now "looking for a new front bumper" :P
The plan is to go full 2019 with dash etc but iam not so good at Canbus etc so here i need some help haha
During the time we are working on some new doors!
Setup: 8x Ground Zero GZCK 200 8" midwoofer 2x Faital Pro FD371
8 pot RS6 Calipers
370mm RSQ5 Discs
EGR Delete
PDF Delete
Turbo GTB1749V
Full Powerflex
