nath25's white mk4
nath25
nath25's white mk4
Post by nath25 »
Ok figured out how to get pictures on here this is my van the day I got it I’ll get more pictures of it and what I’ve done soon
Exuptoy
nath25's white mk4
Post by Exuptoy »
That is sweet.😎
Giddy
Re: nath25's white mk4
Post by Giddy »
@nath25
I've split this from other members build thread, so you have your own now :)
You can edit the title if you want.
Caddy 4, Highline, 1.4 TSI
Instagram: @giddywagen
Build thread >>> here <<<
nath25
Post by nath25 »
ok that's grate thank you still figuring things out post moor pics soon
nath25
Post by nath25 »
Ok not doing much at work today so got some more pics I’ve not done too much with it yet don’t have much money at the moment so what I’ve done is Suspension lift. Repainted mk6 golf alloys 215/65/16 bf Goodrich a/t tyres. Mk2 Audi TT seats. Polo mfsw that I can only get to light up and turn volume down. Remap from 102 to 140bhp painted all light colour trim black inside recovered headlining front and back fitted spot lights in rear headlining. Sound deadening and insulation carpeted ply lining I did myself built my own storage system in the back I’ll get a pic of that when I Hoover it out had I full of old wood. Drilled and grooved disc’s I also fitted a new clutch and flywheel from darkside development think it was dulemass turns out it was already single mass then to top it off after paying £400 and fitting it I had already saved one at work ImageImage
Exuptoy
Post by Exuptoy »
Sweet😎
nath25
Post by nath25 »
Thanks Exuptoy seats could do with some tlc but got them for free from work if we get anything different I’ll change them but they will do for now
nath25
Post by nath25 »
Well I walking around the yard today and I had a brain fart thought it would be a good idea to do an ac retrofit on my van so spent a few hours stripping the dashboard and wiring loom out of a mk6 golf it’s also got a ptc heater as well probably won’t do it until next year now but thought I would get the bits before someone else takes them. Wasn’t an easy job getting the loom out ImageImage
mrhutch
Post by mrhutch »
love it!
Tell me how you lifted the suspension!
06 sdi caddy2k :: 81 Transporter T3 :: 2015 Golf 1.4 TSI :: Freelander (sorry)
Herefordshire and all over.
nath25
Post by nath25 »
I got a set of these from eBay they are from outside the uk you can get them here but they are almost £500 the ones I got are pretty much the same and only £250+pp
mrhutch
Post by mrhutch »
thanks chap, thats the same kit I was eyeing up!
nath25
Post by nath25 »
It’s not a bad kit rear spacers are easy to fit washers for the shackles are rubbish so you will need to change them front ones are a bit more difficult trying to line up all the holes and trying to hold up the leg and trying to get the bolts in apart from that takes about hour and half
nath25
Post by nath25 »
Afternoon caddy chums can anyone help me with a how to guide on fitting mfsw to my 65 plate van I’ve fitted a polo steering wheel and changed the module for a highline one when I code it with vcds I can only get buttons to illuminate and turn volume down steering wheel is without cc there is a picture further up my post of the wheel I have any help would be great I’ve had this fitted since Christmas and still can’t get it to work :lol:
nath25
Post by nath25 »
Not much going on at work today so gave the whip a wash looks much better won’t last long be filthy by weekend also found a pair of fan washer jets at work so changed them as well they are so much better than the 3 nozzle type
nath25
Post by nath25 »
Forgot the before and after pictures Image
