P0299 bls
P0299 bls
Hi this is my first post on my bls caddy on the vcds the boost is registering actual 989mbar specified 193mbar with just turning the ignition on and in idle actual 989mbar specified 1091 mbar please help Iv changed all sensors, played about with all the pipes I just can’t figure out why with just turning the key it’s at nearly 1000 mbar can anyone help me
Re: P0299 bls
Hi, welcome to the forum.
The specified value is the air intake pressure the ECU wants to see. At idle, this will be zero boost so essentially just atmospheric pressure.
Re: P0299 bls
I hope these links work, 1 photo is just ignition on and the other is at idle
Re: P0299 bls
Your photo doesn't work.
Why the concert about the value with ignition on and not running? Everything seems fine from what you describe.
