Cheapest and best mods, you've done.
c13uko
Re: Cheapest and best mods, you've done.
Post by c13uko »
Its the mod for automatic lights for the caddy
Vw caddy raven blue 1.9tdi 104
Jcalvert95
Post by Jcalvert95 »
Can you point me in the right direction to getting one.
Jack Calvert
Caddy Maxi 1.6 TDI
Carlisle Cumbria UK
c13uko
Post by c13uko »
182055327977
That is the ebay number for it pal
syrobs
Post by syrobs »
syrobs
Post by syrobs »
syrobs
Post by syrobs »
So much better than the full grey!
syrobs
Post by syrobs »
*dull
joepaul
Re: RE: Re: Cheapest and best mods, you've done.
Post by joepaul »
Simmo wrote:My air vent surrounds turned up today, are they an easy fit? Anything you know that will make the job easier?
Sent from my D6603 using Tapatalk
I found they need bending over your knee to fit properly, when I say bending, I mean ever so slightly to fit the form of the dash.....don't over do it, they will bend in half very easily.
TDean122
Post by TDean122 »
Best mod I have done was lowering the van cost me £280 for the JOM kit the cheapest and best mod I done was buy a £12 can of colour matched paint and done the badge back, air box and some other bits and pieces.
shanky887614
Post by shanky887614 »
get a plastic battery box, my battery is too big for the felt box
TDean122
Post by TDean122 »
Next will be a engine cover that way it will look a lot better. I was looking at they boxes aswell would the mk6 golf one fit ? Looks the same as the ones I've seen fitted to caddy's
shanky887614
Re: RE: Re: RE: Re: Cheapest and best mods, you've done.
mk5 slot straight on, dont even need to take the battery out they just slot into the battery tray
5mins to fit at most
andysparks
Post by andysparks »
Just got my caddy (1.6 high line 102) and starting to add some mods….. just read that the auto switch for the headlights is a straight swap for the standard switch…. Does this work as not sure where the sensor is or if it’s wired for it?. Mines a 2013 model if that helps??
Exuptoy
Post by Exuptoy »
Suede headliner and carpeted rear, cabin upgrades and Touran seats. I love them all.
Daggz68
Post by Daggz68 »
cadmad wrote:Imagegear knob and wrap both cheap and easy.
Where did you get the wrap from? Previous owner to me added rubbish stickers
Sent from my NTH-NX9 using Tapatalk
