12v Outlet Wiring
DJOHALL
12v Outlet Wiring
Post by DJOHALL »
So I have fitted two 12v outlets in rear of my van and I have the cables ran up to the fuse board. I just need to know where is the best place to connect them to get them to work with ignition on only?
Beaker2135
Re: 12v Outlet Wiring
Post by Beaker2135 »
Some just plug a spade into the front connection and add a fuse in-line but if you want to do it properly this might help for adding connections to the fuse box
In the fuse box upper row of big fuses is pretty much permanent live, the bottom one has few switched live ones if I remember correctly, 33,32,31,30,29,28,27,26,25 should be ignition live
Standard or Maxi power timer is the connector for the big fuses, suitable for a wire size range of 1.5 - 2.5mm2
Junior power timer is the connector for the smaller fuses, suitable for a wire size range of 0.5 - 1.0mm2
Or you can get repair wire from VW
For the larger standard fuses you'll need...
000-979-023E 0.5mm2 wire
000-979-135E 1.0mm2 wire
000-979-227E 2.5mm2 wire
000-979-306E 4.0mm2 wire
If your using the smaller mini fuses you'll need...
000-979-021E 0.5mm2 wire
000-979-133E 1.0mm2 wire
000-979-225E 2.5mm2 wire
Credits;
tommyzoom
stan-the-man
NZDubNurd
Post by NZDubNurd »
WHat he said^^^
Glad you posted it... I can't be arsed :lol: There are a bunch of empty fuse positions. Since converting my Touran from Auto to manual, I have one that's a spare 20A feed to the passenger footwell.
Beaker2135
Copy & Paste :D
DJOHALL
Post by DJOHALL »
Thanks very much! A nice lil job to finish this evening
somacose
Post by somacose »
Beaker2135 : Cheers for that post, I need to hardwire my Sonichi Dab unit and front/rear camera's in to the fuse box so that info will be very handy.
2013 Caddy Highline superchipped but still no match for my Mk2 Golf GTI
Beaker2135
somacose wrote:Beaker2135 : Cheers for that post, I need to hardwire my Sonichi Dab unit and front/rear camera's in to the fuse box so that info will be very handy.
No problem it's all on here somewhere I've just gathered it all together so I don't lose it
Big Pimp
Post by Big Pimp »
Handy information above. Wish I had of seen it last week but I just used a multimeter and found switched and live circuits. Dead handy
Cadilacer
Post by Cadilacer »
Hi
I'm finally getting round to running a wire to headroom storage to power dashcam and Sat-Nav.
Does anyone have a an itemised fuse list. . . ?
Seems hard to track down
2012 Caddy 1.6tdi
Andrejm
Post by Andrejm »
I found empty fuse #28 that stands for 12-V socket 3 -U19 in storage compart, that is powered with ignition on, and 20A fuse, read on fuse diagram.
This is not the same as cigarette lighter 12 V outlet in my caddy life trunk, because is constant live.
Little confusing, mqb platform has in fuse connections 30 or fuse 15 to set on cigarette lighters outlets, from constant on(30) to ignition live(15), but caddy dont have thi options.
This #28 fuse i will use for power amplifier remote wire..
