R32 exhaust
R32 exhaust
Hi all, new to all this forum thing, looking at getting an r32 style exhaust, what options do i have? Does the original r32 exhaust fit or is it a conplete custom build i need?
Re: R32 exhaust
It will have to be custom, the golf didn't have a solid rear beam to contend with so the exhaust from such won't fit a Caddy.
- dan@biali
Re: R32 exhaust
You can use an R32 backbox or even the Golf R as the backbox for yours though, and that also means using aftermarket versions for either. I had a Milltek MK6 Golf R backbox on mine with a custom link pipe and believe Matt@reflex's blue Caddy had a MK5 R32 backbox. Another issue is the spare wheel and bracket (I removed mine) and as Doc points out, you will need to be careful with the link pipe clearing the rear axle.
Re: R32 exhaust
Ok, thank you bot for your responses, thought id be waiting days on end for a reply! But thanks for the info and the heads up, hopefully will have one sorted soon!
Re: R32 exhaust
i had a custom one made for mine:
Re: R32 exhaust
I love the look of the r32 style exhaust! Looks smart
Re: R32 exhaust
Very nice. Is there much work needed on the bumper?
Re: R32 exhaust
What sort of sound do these systems give?
had a mk4 r32 with a 3" system and it used to wake the dead!!
- Barbel330
Re: R32 exhaust
I had my rear box removed and a custom 3" pipe to R32 style twin 4" centre exit tips and it sounds literally no louder than it did with the standard box.
Instagram: @y_5cuf
Re: R32 exhaust
Shame, that's diesels for you tho, ive a 335d at the moment, barely any exhaust note at all despite it having 360bhp
- Barbel330
Re: R32 exhaust
Need to get rid of all the gubbins up front to get some sound out of it I think. Egr, dpf, cat etc, not that I wanted mine loud anyway but a slight rise in volume wouldn't have hurt
Instagram: @y_5cuf
Re: R32 exhaust
Yeah it's easy enough with a petrol lump just knock the guts out of the cat and stick an induction kit on
Re: R32 exhaust
Yes, take a hammer and chisel and persuade the inners of the cat loose....
