My new Caddy 4 build thread
stan-the-man
Re: My new Caddy 4 build thread
Post by stan-the-man »
Thank you buddy!
The wheels are 18" Sebring 7.5x18 et51
Love em!
deutsch
Post by deutsch »
stan-the-man wrote: Mon Oct 09, 2017 2:00 pm Image
Managed to fit and code them last night.
Wow what a improvement Image
what tool did you use to code the keys ODIS or something else??
VCDS (VagCom)
VAS / ODIS VW Audi Seat Skoda (Dealer Level / Online Access / Component Protection / Keys / Coding)
VagCAN PRO
AVDI
gogsie
Post by gogsie »
Do you have part numbers for the rear wiper, i've been searching everywhere and can't find one.
stan-the-man wrote: Mon Aug 28, 2017 12:46 pm T5/T6 rear wiper installed. I feel my van is much faster now Image
stan-the-man
Sorry gogsie never seen this . Will post them asap!
stan-the-man
Testing heated steering wheel currently...
She works!!!ImageImageImageImageImageImage
stan-the-man
T5/T6 rear wiper conversion:
7H0 955 707 left aero wiper arm
7E0 955 425 A aero wiper blade
6Q6 955 435 D cap
7E0 955 758 A bearing seal
N 106 092 04 collar nut
I don't think you need the last two . I think I reused my original nut and didn't use the seal.
Sportvan
Post by Sportvan »
Heated steering wheel! I would love this on my van! Also do you know how to enable cross traffic alert ? I have park assist and front and rear sensors
stan-the-man
Haven't got that far yetImage
Yup absolutely fab this morning 🤣Image. Won't be using setting 3 on seats much as it will be too much I'd say.
Should be changing leds later this week from white to red.
Sportvan
Post by Sportvan »
Is that a golf mk7 steering wheel with acc and paddles? Can these be fitted to the caddy 4? I’ve got adaptive cruise but would love paddle change instead of knocking the stick about!
Sportvan
Post by Sportvan »
I prefer the white. Easier on the eyes and to see at a glance.
So does the mk7 golf wheel work in the latest Caddy’s?
RKDesigns
Post by RKDesigns »
Yes, but there are differences in the knobs between steering wheel versions of the golf 7 so not each steering wheel is a direct fit!!! GTI GTD R need other modules in many cases to get these working. Other airbag cable.
stan-the-man
This is new touran wheel. I tried the sports mk7 wheel and it would work at all. Got that one to try with idea to use my button panel but because it lacks the connections for paddles at both sides I decided to try original with it.
It works perfect ImageImage
The paddles are no good to you with manual.
Last night I changed the leds on the wheel. Left couple white per side as well. Looks awesome imo. Pictures don't give it justice.
needforspeed
Post by needforspeed »
Hi! I want to retrofit TPMS and High Beam Assist to my Caddy 4 I was wondering if you have any info?
Bright Spark Auto Electrical
07947719580
https://www.facebook.com/brightsparkautoelectrical/" onclick="window.open(this.href);return false;
stan-the-man
Both should be doable. You'll need compatible module and 4 wheel sensors for tpms for HBA you'll need to change your mirror, if you don't have rls then the windscreen more likely
Cbaker9076
Post by Cbaker9076 »
stan-the-man wrote:Today I managed to fit one of the new touran 5T puddle lights into one of my mirrors.
Very pleased with end result.
There isn't much room in there as the light unit itself isn't the smallest.
Had to shave off the area to make the light flush with the trim.
Overall delighted!
Hi Stan do you still have the part number for the touran puddle lights please thank you
