My EX BG VR6 3.2 build
- S3_Oj
Re: My BG Caddy maxi build
Sweet build there pal Van is looking spot on
Just a quick 1 regarding your breaks do you only need to change the caplier carrier to get then to fit ?
Keep up the good work James
- S3_Oj
Calliper
- Sean1066
Thanks James
I'm not to sure I'm going to change my disc anyway to 354mm disc.
I'm looking at EBC 345mm turbo groove GD Discs with yellow stuff pads
- S3_Oj
Some stopping power there am gutted as I just missed out on a set of golf R discs n callipers.Sean1066 wrote:Thanks James
Could you let us know when you get round to fitting them how hard it was and what you need to get them to fit.
Would appreciate that
- Sean1066
No problem
when I get them all together and them got round to fitting I will post pictures on here
I’d be interested to see how they look in red. I’m considering painting mine either red, or black
- Sean1066
My centre console arrived today.
Needs a good clean be for I fit it in.
So now I need to find a weekend where I’m not working so I can fit this and me carpets.
- Sean1066
I managed to get one of the calipers spray red today
- Sean1066
Front calipers all done now just waiting for the discs and pads to turn up
- Caddyluv
Just if your interested. You can get a large clip I found these. I don’t know if there the cheapest but an example.
https://rover.ebay.com/rover/0/0/0?mpre ... 3116830540
These are mine.
These are mine.
- Sean1066
I wanted to get something like that.
But I didn’t know if would fit
I’m going to have to get them
- Caddyluv
Mine were very tight. Guess that’s the point. But yeah all good.
- james400
I got mine from Ebay £25 new.
- Sean1066
I have ordered some off eBay £11. Need spraying.
Should look a lot better than the smaller ones.
- Sean1066
Finally my discs and pads have turned up and ready to fit
