My Blackberry Caddy
hef355
Re: My Blackberry Caddy
Post by hef355 »
Nice Stu, tint of metallic in that gloss black, lovely!
brooneye
Post by brooneye »
They look nice. Doing a cracking job pal
Post by Stedlocks »
so nice and spangly!
Barbel330
Post by Barbel330 »
Next up on the operating/garden table is the front bumper so I can cut, weld up and make fit the front wheel arch extensions. The arch kit is designed for a mk4 so the front wings and bumper sections are different to my mk3, plus I have a custom bumper so everything needs some adjustment.
The wing arch piece is too long for my van so I marked and cut a section off.
Then the bumper piece is too short
And the bottom doesn’t fit the shape of my bumper
The piece which I cut off the wing arch is going to be used to extend the bumper piece
They are then plastic welded together
Inside and outside
Sanded and ready for a skim of fibre tech filler.
The arch then needs a little bit of heating up so I can get it to fit the shape of the bumper.
Before
After
Also needed to trim the lip of the wing sections so I can air out without it touching the tyres
Instagram: @y_5cuf
Berger
Post by Berger »
Mate I wish I had your skills can’t wait to see it when it’s done
Instagram @berger2k
Poopcamp
Post by Poopcamp »
Damn!
Barbel330
Post by Barbel330 »
Thank you mate.
I'm learning as I go with all this plastic welding tbh. Although I've done a bit in the past for my work that's been more crack repairs, I only got an actual proper welder a few weeks ago. I've used it a hell of a lot since I got it though so it was a good buy for £65 :) I even had to use it on my mirrors yesterday when I snapped a lug off, not sure how I got by without one now :D
Instagram: @y_5cuf
Gary.8
Post by Gary.8 »
Top work that stu looking forward to seeing it all finished.
Like Berger said i wish I had your skill...
Barbel330
Post by Barbel330 »
Cheers Gary
Instagram: @y_5cuf
Celticrsmith
Post by Celticrsmith »
Gresley
Post by Gresley »
Brilliant work on those arches and your whole van in general. I've had to do a lot of arch work myself and it's not easy. Look forward to seeing all the new additions.
Barbel330
Post by Barbel330 »
Cheers.
I'll try to get them primed in the morning, then painted asap. I'm getting a bit fed up doing all these little parts tbh, I'll be glad when they're finished. They need to be primed in black due to the blackberry needing a black surfacer which is all extra hassle :? Should be worth it in the end hopefully :)
Instagram: @y_5cuf
Gresley
Post by Gresley »
I feel your pain regarding working on lots of little parts. Definitely be worth it in the end!
hef355
Post by hef355 »
Brilliant work Stu!! Thinking of this kit just for the rear of my van as my 10 x 20 rear wheels protrude the rear arches and this arch kit would suit i think, i’m sure you would fit mine for £20 wouldn’t you
Barbel330
Post by Barbel330 »
£20 a minute and I'd consider it Hef :lol:
It's a lot of work for something that 99% of the population would never even realise is there :)
Instagram: @y_5cuf
