Wind noise
Wind noise
So now that the rear is soundproofed and carpeted my attention has changed to the wind noise in the cabin.
Any solutions for this?
- Barbel330
Re: Wind noise
Do you have standard big mirrors? Wind deflectors make a lot of noise if you have them.
Instagram: @y_5cuf
Re: Wind noise
Standard dumbo mirrors.
No deflectors.
No deflectors.
- Giddy
Re: Wind noise
You sure it's not the 'mirror whistle'? It is a topic in 'how to' section https://www.caddy2k.com/forum/viewtopic ... 22&t=16444
Re: Wind noise
i ve got the same problem had it from new,i did try adjusting the doors to close tighter but didnt do much. i am going to get the duct tape out and seal the door up till i find out where the problem is
Re: Wind noise
@Giddy. No not the mirror whistle. The noise in the cabin sounds like the window is slightly open
Re: Wind noise
@skinnyd I have the same issue, I can actually see the outside world through a gap between the door seal and where it meets the body, approx 1-2mm not sure how water doesn’t come in tbh!
Re: Wind noise
I did read somewhere about a second door seal. not sure where or how but said to help a fair bit
- robblowen
Re: Wind noise
I had a look for that the other day, anyone confirm if it's no.9 and whether it fits and/or makes much difference?
Re: Wind noise
Interesting to know if the life models have extra insulation as well?
Re: Wind noise
The extra door seals are £41.02 from VW including VAT. They are listed as being for, "Comfort equipment", "sports/convenience version" or "high luxury equipment level"
It's on my to do list after I get some money back in my caddy funds piggy bank.
- robblowen
Re: Wind noise
Cheers doc
Re: Wind noise
Thanks @doc.
Does the sliding door also have extra insulation options?
Re: Wind noise
Bad door seals is the most common problem with wind noise. I had Them all renewed when ik bought my 180K second hand caddy. Doors are really snug now. Wind noise is a lot less now
- Stvxrt
Re: Wind noise
has anyone here fitted the comfort door seals? from what I can see on partslink, the seal on the door and on the van will both need replacing. after searching google images it looks like the caddy life has them as standard?
