My ex British Gas conversion
R25kav
Post by R25kav »
Quaility build keep up the top work .
Got my self a british gas maxi last weekend
robblowen
Post by robblowen »
@R25kav cheers, it's a slow process but it's getting there!
robblowen
Post by robblowen »
A few more photos in better light, cab roof lining dyed darker, wiring all in place for switch panel, rear speaker cables plumbed in, split charge power cable run in, floor cut and bolted in place, L track bolted to the floor, flooring turned up today so get that cut next!ImageImageImageImageImageImage
R25kav
Post by R25kav »
What did you use for the cab roof lining mate .
Ye defo a slow process and an expensive one
olig
Post by olig »
Nice one Dude, I'll send you my email address.
robblowen
Post by robblowen »
@R25kav ebay number is 121728097596 works a treat, evaporates real quick if you leave the lid off try to use a put, definitely use the spray top and a sponge to spread!
R25kav
Post by R25kav »
@robblowen
Top man got some of that ordered now
Touran rear seats coming Friday so hopefully I can figure the seat belts out .
Keep up the good work mate
R25kav
Post by R25kav »
robblowen wrote:Upper catch cover.ImageImage
Hi mate can I ask what you have used to cover the seat belt reals . Are they factory covers or have u made them .
robblowen
Post by robblowen »
@R25kav the seat belt reel covers are from vw, plastic trim then I carpeted to blend in, the part number will be something like 2k0867263, you'll be able to get the right one with your reg, they were only about £6 each from vw, you'll also need 8 of the little clips that hold them on.
R25kav
Post by R25kav »
robblowen wrote:@R25kav the seat belt reel covers are from vw, plastic trim then I carpeted to blend in, the part number will be something like 2k0867263, you'll be able to get the right one with your reg, they were only about £6 each from vw, you'll also need 8 of the little clips that hold them on.
Thanks again mate sorry for all the questions Image
mrdepths
Post by mrdepths »
i follow your IG account.
Some great stuff here.
robblowen
Post by robblowen »
@Mrdepths cheers man
robblowen
Post by robblowen »
So latest update - SHIT!!!! Suspect an injector just waiting for the aa and still a long way from home!!!Image
peely
Post by peely »
It’s just pants ain’t it , just recently done all 4 of mine ,, feel your pain , get on to Vw customers care and see when your update was done you may get help with cost if it’s under 2 years , good luck 👍👍
robblowen
Post by robblowen »
@peely yeah man really sucks! I've decided on buying 2 reconditioned injectors, fit one, keep one as spare in the van, then fit and engine cover and get it remapped and hopefully never need the spare!!!
