Heat exchanger auxiliary heater
- james400
Hi guys I cant seem to find the how too page regarding how to fit and wire up the auxiliary heater can anyone help on this? Thanks
- tommyzooom
Re: Heat exchanger auxiliary heater
Is THIS it?
- james400
Thanks mate did anyone ever do a how to on this? I'm sure I seen some one putting photos up of one being fitted ?
- tommyzooom
I don't think there was a Caddy specific one.
There is a Mk5 golf how-to, in the 7th post in the thread linked to above
- james400
No problem I've just ordered one so I'm going to have a look at it when it comes and I'll try and do a how to thanks mate
- james400
Which one did you go for 1K0963235E or 1K0963235F can you remember?tommyzooom wrote:I don't think there was a Caddy specific one.
- tommyzooom
E. although D is also the same "smart" element.
F is a "dumb" relay based version
- james400
I've found a 1K0963235c is that the same as e/d?tommyzooom wrote:E. although D is also the same "smart" element.
- james400
tommyzooom:
Hi mate is it just the can lines that go into the plug terminals 1& 2 do u no what 3 & 4 do? Thanks
- Beaker2135
Just pins 1&2
Pin 1 to orange/green
Pin 2 to orange/brown
- james400
Thanks just wanted to double check
- james400
Fitted it just need to wire it up can u use the can lines from the heater controller for it or not?
Yes, the heater goes on the convenience CANbus, same CANbus as the heater control panel if you have climatic or climatronic.
- james400
Thanks doc
Hi everyone.
How to wire dumb version, what controls the relays?
Thanks in advance.
Rene
Thanks in advance.
Rene
