6 speed conversion
6 speed conversion
Hi guys I know somewhere on here this mite have already been asked but I have a 2011 caddy 1.6 75hp what would I need to convert to 6 speed cheers
- Lister79
Re: 6 speed conversion
Hi mate I’m sure someone else will confirm (as I could be wrong) but I’m sure the easiest way is to use an MYP coded box from a Passat 1.6TDi and swap the cups over from your box. However I don’t think the cruise or gear display will work when in 6th.
[mention]Lister79 [/mention] and [mention]gidyon06 [/mention], can you confirm that for a 1.6 L TDI, you were able to install a 6-speed MYP gearbox with only a swap of the flanges? Any other parts needed? Is your MFD reading the 6th gear and is your cruise control working? And what plate is the Caddy? Cheers and thanks from Germany
- gidyon06
@eph3
This is correct dude, and it won’t show 6 but cruise control works fine.
No other parts were needed but you will need to adjust your gear selector
6 speed conversion
Hi sorry to hijack mine doesn’t show 6th and the cruise control doesn’t work in 6th either. Anything I can do to fix this?
It’s a 2014 Cross Caddy 2.0TDI
- gidyon06
6 speed conversion
So at the moment I haven’t found anyone that can change anything in the ecu so that 6 is recognised.
I will get out in my van today and try the cruise in 6th I am sure it did work.
Thanks for the confirmation of the install! This summer I'll probably make the swap. Did you get a chance to check cruise control in 6th?
- gidyon06
So went out in the van last night and I can confirm my cruise works as it should when In 6th gear
Damn you lucky mine doesn’t work in 6th 5th works 6th nothing
