Auto lights
Auto lights
Hi, i have a 64 plate caddy highline and would like auto lights and coming home lights, is this an easy conversion? i have found an auto light kit on ebay with sensor that seems to delay the drls which would be fine. would this be the easiest/cheapest alternative? many thanks for any advice.
Re: Auto lights
eBay jobbie for around £15, works perfectly! One of best and easiest mods to do
Re: Auto lights
That’s one of two things I wasn’t happy that I didn’t get! I also wanted auto wipers but had low mileage
Could you please post the link?
Re: Auto lights
Im also interested in this, will follow you guys.
Re: Auto lights
Anyone got a fleabay link to these? ta.
- JayLipscombe
Re: Auto lights
eBay item number: 112136169551 this is the one I used
Re: Auto lights
I’m guessing the sensor goes in the bottom of the windscreen?
Caddy Maxi Kombi 63 plate
- Cabbs
Re: Auto lights
Correct or to one side near the drivers side dash airvent. Easier to route your wire then.Photex wrote:I’m guessing the sensor goes in the bottom of the windscreen?
- Caddyluv
Re: Auto lights
Mines at the top of the A pillar tucked it right on pretty much invisible unless your really looking for it.
- reflectionghost
Re: Auto lights
Is the fitment of the sensor and routing of the cable much of a task?
Re: Auto lights
I fitted one of these but have never been able to work out how the leaving/ coming home function works.
