My caddy maxi 2010
- linass
My caddy maxi 2010
Volkswagen Caddy maxi, 2010, 1.6 TDI 75kw, manual gearbox.
Still has all the original, but not for long.
- linass
Re: My caddy maxi 2010
With new wheels. Vossen cv3 replica, R18 8j ET28 tires 225/45 ,
Those vossen reps look sick dude!
I have 2009 version (van), but latest versions, like yours, are really beatyfull.
Sorry for my bad english from Spain...
- linass
Spring upgrade: lowering the springs in the front, lowering the rear and brand new wheels (vossen cvt replica, 8.5 "ET38, 225 / 35R19)
- torque777
Looks great
Evening,
Caddy looks great. I am having alloys, side bars and roof rails fitted to my Caddy Maxi on Thursday and wanted the garage to lower it 40mm but told it’s not as easy as that.....they say you can get springs for the front and that the back just need flipped over to lower but explained that it may take a days labour £500 and involve removing the rear axle. Any info would be appreciated including where you sourced your springs.
- Afield23
That seems a bit steep! I don't think the axle has to come off pretty sure the leaf springs just get put on the underside of the axle using the new clamps.
Sent from my SM-G928F using Tapatalk
- linass
the axle wont need removing just supporting then they can remove the spring then refit it but under the axle instead of on top and fit the new adjustable brackets for the leaf springs should take a garage with a ramp an hour to do the rear and an hour to fit front springs so id say 2-3 hours max to lower it
Oh, that`s a beautiful maxi
@linass
"Vossen cv3 replica, R18 8j ET28 tires 225/45"
Loving those wheels looks slick as f**k
Reason: removed picture quote and added username tag
- Lister79
Looks superb mate, great color choice
It’s looks tidy mate. Have you put coilovers on as it looks low for springs.
Love the colour
