Indium Grey Build
PDC
Re: Indium Grey Build
Post by PDC »
No it didn’t have any foam on the back and I would stay away from anything foamed backed as you will struggle with the added thickness where panels overlap and around door seals......
PDC
Post by PDC »
Just fitted LED’s into the tailgate, they have made a huge difference lightning up the area of the tailgate while loading.
PDC
Post by PDC »
Also fitted the side track for the sliding door with the built in clips for the cover rail. I was never happy with the way the trim cover sat without the retaining clips. The part numbers posted by some members I found to be wrong and luckily for me my local VW dealership after having ordered two rails and both being wrong ordered all four variants for me. I have taken a photo of the part number and the rail.
Giddy
Post by Giddy »
Yep, the rail is different for Caddy 4. Couple holes don't align.
Caddy 4, Highline, 1.4 TSI
Instagram: @giddywagen
Build thread >>> here <<<
PDC
Post by PDC »
Yes I still had to open up two holes just to get it all to line up.........
Yvg
Post by Yvg »
thank you for the info!
ordered a small amount for my door cards, might going to try some stretch suedine, as it is really cheap to do the headliner.
again nice build you got! :D
PDC
Indium Grey Build
Post by PDC »
Ok so I have at long last finished carpeting the inside of the van this weekend. Image
Giddy
Post by Giddy »
Looking good mate, well done.
PDC
Post by PDC »
Many thanks, next phase will cost a little more money now, I want to colour code the side strips and spray gloss black all the grill bits. 😃
PDC
Post by PDC »
I managed to find time between the rain showers to fit the front mud flaps & my 2K sticker.
Lookin great mate, Iv recently got a 2018 same colour as yours, starting to share some mods!
Be a while before mine looks anything like yours though!
I'll keep my eye on yours
PDC
Post by PDC »
Hi Gazza, I guess it's slightly cheating starting with a new van, as a lot on here will spend a lot of time fitting things that my van came with from the factory. That said looking at some build threads on here there is still an awful that you can do with a new or nearly new caddy and I probably won't do half of them, but I do seem to keep adding to the list weekly....... 🤣 I will look forward to seeing how you progress with your too. 👍🏻
Angood123
Post by Angood123 »
How much of the stretch suede did you have to order? Recently bought my caddy and would love to do the cab headlining.
cheers
PDC
Post by PDC »
Hi Ya,
It came 1m x 1.5 meters and I had to order two lots. You will however get away with 1m x 1.5 if you don't trim the B posts. 👍🏻
RKDesigns
Post by RKDesigns »
PDC wrote: Sun Nov 03, 2019 12:02 am Ok this weekend I fitted an engine cover from an Skoda Octavia. I purchased the VW badge separately and glued it on with a bit of Araldite.
get the Skoda logo out of it and there is a vw logo underneath ;)
