- mikenorman
Thanks novakid! I take my time on building them to get them to how I want them to look.
- DeanWhit
A service this morning followed by a couple of hours sound proofing the back.
Need to do the roof and then I can finally get it carpeted.
Paid for it
Bring on Tuesday
Bring on Tuesday
- Josh764
Sorted wheels and coilovers late yesterday, really pleased with how it's turned out. Managed to squeeze the 9J wheels on with 245/45's. 8mm spacers on the front backs went on without spacers, sliding door is close but opens fully
- Novakid
That wheels look mint Josh
- Josh764
Thanks buddy, was worried they wouldn't go on,, so glad they have.
- gazza31112
Yea I like them, fill the arches up a treat
- RKDesigns
Under a 1.6TDI you can even mount 10J with just a little change to get the doorcard a bit more in it still let fully slide open the slidingdoor. With the 2.0 TDI 140hp 8,5J already comes out
Finally got round to changing the rear shocks, old ones had blown
- Beaker2135
Decided it was cold enough to fit the winters
Finally got my reverse camera working like Oem big thanks to @r1lea
Then took my back roof lining down to insulate behind it
Played with the Obdeleven, but used the vagcom to activate « indicator celebration» Needlesweep..
- BillyGilly
Replaced injector seals, oil & filter change.
BillyGilly
2016 2.0 TDI Bluemotion: viewtopic.php?f=13&t=40889&p=341148#p341148
2009 2.0 SDI: viewtopic.php?t=40416
Hello Sean,
I see that you are in the same case as mine : update RNS510 into Discover Media PQ . But i have a TOURAN MY 2014 . I think i hjave to change my gateway prior to go to VW to ask for Component Protection descativation.
I plan to install a 7N0 907 530 BC. Actually i have a 7N0 907 530 AN and with VCDS i don't see the unit in the "installation list"
Could you tell me , if it's possible for you, if you have this model of Gateway installed in your car ?
Thank you very miuch in advance
Sincerely yours
Emmanuel
- Sean1066
Hi Emmanuel
My discovery media I bought off spacewalker and it was plug and play and already component protection removed
So I didn’t need.
As for the gateway I couldn’t tell you what model number it is without vcds.
So I didn’t need.
