mikenorman
Post by mikenorman »
Thanks novakid! I take my time on building them to get them to how I want them to look.
DeanWhit
Post by DeanWhit »
A service this morning followed by a couple of hours sound proofing the back.
Need to do the roof and then I can finally get it carpeted. ImageImageImage
Lad.In.A.Cad
Post by Lad.In.A.Cad »
Paid for it
Bring on Tuesday 8)
Josh764
Post by Josh764 »
Sorted wheels and coilovers late yesterday, really pleased with how it's turned out. Managed to squeeze the 9J wheels on with 245/45's. 8mm spacers on the front backs went on without spacers, sliding door is close but opens fully ImageImage
Novakid
Post by Novakid »
That wheels look mint Josh
Josh764
Post by Josh764 »
Thanks buddy, was worried they wouldn't go on,, so glad they have.
Yea I like them, fill the arches up a treat
RKDesigns
Post by RKDesigns »
Under a 1.6TDI you can even mount 10J with just a little change to get the doorcard a bit more in it still let fully slide open the slidingdoor. With the 2.0 TDI 140hp 8,5J already comes out
Fonzi
Post by Fonzi »
Finally got round to changing the rear shocks, old ones had blown :( Image
Beaker2135
Post by Beaker2135 »
Decided it was cold enough to fit the winters
Ant bliss
Post by Ant bliss »
Finally got my reverse camera working like Oem big thanks to @r1lea
Then took my back roof lining down to insulate behind it
fazerfreak
Post by fazerfreak »
Played with the Obdeleven, but used the vagcom to activate « indicator celebration» :D Needlesweep..
Best Regards
Tommy
My Caddy
BillyGilly
Post by BillyGilly »
Replaced injector seals, oil & filter change.
BillyGilly
2016 2.0 TDI Bluemotion: viewtopic.php?f=13&t=40889&p=341148#p341148
2009 2.0 SDI: viewtopic.php?t=40416
fwi98
Post by fwi98 »
Sean1066 wrote: Fri Aug 30, 2019 5:04 pm Finally got the head unit I wanted and fitted in in today.
Discover media
Hello Sean,
I see that you are in the same case as mine : update RNS510 into Discover Media PQ . But i have a TOURAN MY 2014 . I think i hjave to change my gateway prior to go to VW to ask for Component Protection descativation.
I plan to install a 7N0 907 530 BC. Actually i have a 7N0 907 530 AN and with VCDS i don't see the unit in the "installation list"
Could you tell me , if it's possible for you, if you have this model of Gateway installed in your car ?
Thank you very miuch in advance
Sincerely yours
Emmanuel
Sean1066
Post by Sean1066 »
Hi Emmanuel
My discovery media I bought off spacewalker and it was plug and play and already component protection removed
So I didn’t need.
As for the gateway I couldn’t tell you what model number it is without vcds.
Caddy maxi 3.2 VR6 EX BG
My build thread
