My ex British Gas conversion
BradleyB
Post by BradleyB »
Some great work in cold conditions
Well done fella
robblowen
Post by robblowen »
@BradleyB Cheers man, trying to tick off little jobs when I can. Just been too busy for too long!
robblowen
Post by robblowen »
Finally finished wiring in the split charge system, next to get the roof lining and lighting done in the back!Image
robblowen
Post by robblowen »
Had a go with some simple coding jobs as well, managed to activate needle sweep, door warning lights and deactivate PWM on the LED number plate lights.ImageImage
peely
Post by peely »
Just a quick question mate , I have gas van and would like the needle sweep , I tried but it said error on VCDS could you tell me how you did yours 👍
robblowen
Post by robblowen »
@peely Yes mate, open vcds, ignition on, select control module, select 17 - instruments, select adaptation, click drop down list - select ENG112417 indicator_celebration (towards the bottom of the list), click new value, select active, click do it, click ok, click ok, go back to first screen, ignition off and back on again and admire your handy work! Hope that helps dude.
Gary.8
Post by Gary.8 »
@robblowen thanks for that..
like @peely i got error when I tried it under staging (I'm using OBDeleven) did it using indicator_celebration and it works
robblowen
Post by robblowen »
Awesome, glad it helped!
peely
Post by peely »
Cheers mate will look tomorrow 👍👍
BradleyB
Post by BradleyB »
@roblowen
Hi mate too work yet again
Would love the needle sweep but I’d be scared to try coding myself
robblowen
Post by robblowen »
@BradleyB cheers man, honestly it's really simple to do, that's why I chose it for my 1st attempt! Haha
peely
Post by peely »
robblowen wrote: Mon Dec 30, 2019 1:53 pm @peely Yes mate, open vcds, ignition on, select control module, select 17 - instruments, select adaptation, click drop down list - select ENG112417 indicator_celebration (towards the bottom of the list), click new value, select active, click do it, click ok, click ok, go back to first screen, ignition off and back on again and admire your handy work! Hope that helps dude.
Mmmm mine still saying error: channel not available, my bcm must be lower than a start line 😤
peely
Post by peely »
Gary.8 wrote: Mon Dec 30, 2019 2:37 pm @robblowen thanks for that..
like @peely i got error when I tried it under staging (I'm using OBDeleven) did it using indicator_celebration and it works Image
What’s staging Gary 👍 obd eleven ?
Gary.8
Post by Gary.8 »
This is OBDeleven https://obdeleven.com/en/apps-and-features
needle sweep (staging) in long coding Image
BradleyB
Post by BradleyB »
So I can do it via an app no software or computer needed ???
