Hi,
I'm in need of some help, for the past couple of weeks I have been having problems with the dash lights. When I indicate left on my dash the exhaust gas warning light faintly comes on and off, so does the right arrow indicater. But when I indicate right it works normal!
I hope someone can help!!!
Regards
Ben
Problem with my caddy dash!
Re: Problem with my caddy dash!
Sounds like a bad earth somewhere?
If this is on the old red display instrument cluster fitted on the caddy from 2004-2010 then it is more than likely a failure at circuit board level.
I've seen it a few times where random lights come on with others.
Because the immobiliser is integrated into the instrument cluster it is not a simple swap out.
That doesn't sound good! Where is the Earth for the lights?
Can anyone help please?
Which generation of caddy/instrument cluster do you have?
2010 caddy maxi
