Mk3 pre facelift front end conversion
How’s things all. I’m new to the forum and just finding my way around. Can anybody tell me will a facelifted front end for onto the old shape 1.9 caddy mk3 and is it a big job to convert. Will the bonnet lights wings and bumpers swap over easily
Re: Mk3 pre facelift front end conversion
Hi, welcome to the forum.
Which facelift front are you thinking, 2010-2015 or 2015+?
Both are possible, neither are particularly easy.
Cheers mate
Did you get any further with your facelift ?
04 Caddy SWB
2.0 BYD DSG Swap 360bhp+
Instagram - @racecaddy
Hey man. Just done mine and it’s quite involved but is do able as Doc said. Plenty of parts are needed and there is a comprehensive list further up the forum.
Can anyone please give me a comprehensive parts list for a 2008 caddy facelift to a 15+ front end
- dan@biali
Just to confirm, you mean the MK4? There are lists on the forum but to do it correctly you will need bonnet, grill, wings, lights, bumper, front quarter light windows (they're a different shape than the MK3) and I suspect a load of other bits (on the MK3 you need the different pieces at the front for the wings to attach to) and if you're going to do it properly then you will need doors as well as the MK4 has a subtle swage line leading back from the wings which the MK3 doesn't, and then you open a can of worms because the door cards are different which if you use the MK4 ones won't line up with the dashboard plus you would need to repin and code the locking modules and the BCM (or is it CECM I can never remember!) as they are different as well!
Is there a place to see the comprehensive list on what parts you would need to do either of the facelifts thanks
- Papa Bear
https://www.caddy2k.com/forum/viewtopic.php?f=22&t=518
Good list here
Good list here
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
Any photos of a caddy that’s been facelifted ? Jw as I wanna do myn soon thanks
Thanks for the link mate
Re: Mk3 pré lifting avant conversion de l’extrémité
I'm interested by mk4 front conversion for my 2010 caddy. Is the 2016 caddy life wing mirrors fitted on mk3 doors? Thanks for your help
Caddy 2010 - mk6 gti 312 brakes - mk7 r steering wheel - 18" vw motorsport
Hi new to this site seen your link for the caddy conversion but it's not letting me view it
- Giddy
@Jmcguigan
Welcome to the forum. That's because you're a new member and haven't got an access yet.
Meanwhile, make sure you understand this post https://www.caddy2k.com/forum/viewtopic.php?f=3&t=31039
Instagram: @giddywagen
Caddy 4, Highline, 1.4 TSI, Build thread https://www.caddy2k.com/forum/viewtopic ... 13&t=37368
