Alright guys wondering if anyone could help I want to remove the lower bumper skirt there’s no visible screws in it so I’d imagine it’s bonded on with adhesive as the owner before me had done it.
Question is what’s the best way to remove this without damaging both the bumper and the skirt any help is greatly appreciated
Removal of Front bumper lower splitter?
- Azz03
- Dav02
Re: Removal of Front bumper lower splitter?
Heat & fishing wire or plastic trim removing tool. Try those. That's how I removed the rear badge (fishing wire) and side strips (trim remover).
Once you have it off use a caramel wheel to get rid of all the left over adhesive.
- DeanWhit
Or tooth floss
- Barbel330
If it’s bonded on you’re going to struggle
Instagram: @y_5cuf
- Azz03
Cheers guys I’ll give it a go worse case I’ll just cut it off as I won’t need it anymore due to a new one.
