Marts Caddy
Marts Caddy
Hi peeps thought I’d start a build thread as been playing about with the caddy I brought last week.
These are the photos the seller took
Mechanical the van is sound but bodywork up close isn’t great so I started to see how much of the scratches etc I could get out with g3 and a polisher
Managed to get a lot of the scratches out of the van but the front wings are quite bad and dented so went on eBay to hunt for a pair of wings
These seem great value so ordered them up!
Next parts to order are wing mirror trims as mine are missing
Re: Marts Caddy
Does anyone know why the photos ain’t showing.
I’m using google photos to create a link for each photo for example:
https://photos.app.goo.gl/889UfvecCDKbw3d67
Then putting and the link in the middle of that.
Am I doing something wrong?
- Ripley55
Re: Marts Caddy
Not seeing anything ? I’m using Tapatalk and that’s been fine for uploads
- gazza31112
Re: Marts Caddy
Same
Re: Marts Caddy
Ok guys I’ll download that app instead cheers!
- gazza31112
Re: Marts Caddy
I also have to compress all my photos I take from my phone i upload using a app called lit photo, not sure if thats the same as others? Never thought to ask tbh?
- tonyhill
Re: Marts Caddy
Pics are showing bud
- gazza31112
Re: Marts Caddy
Yea seen em, just me then
- Papa Bear
Re: Marts Caddy
They weren’t showing but are now
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
Re: Marts Caddy
That’s done it guys cheers
The next thing I had to do was put the bulkhead back in and was just in the back with a bag of fixings the joys!
Now that’s all back together. I wasn’t happy enough with the bodywork after polishing and knew I need to spray the wings anyway which have arrived.
Now onto the repairs on the van, I didn’t get a close up photo of the rear door but it looked like it had been sprayed before badly so started rubbing it down.
This was the panel I initial polished and got the scratches out but was still left with a nasty crease in the panel.
Body filler applied.
The other door had a small dent just below wing mirror, filler applied.
That’s both panels repaired, had a nasty dent on the bottom of the other rear door aswell
Pulled out the best I could get it.
Filler applied and rubbed down.
I will say now I’m no professional when it comes to bodywork I’m self learning as I go. Im better on the tools. I’ve already learned that spraying the primer right up to the masked area only gave me a headache as was harder to run down the primer.
- gazza31112
Re: Marts Caddy
Jumped right into that didn't ya lol fair play mate
Re: Marts Caddy
Time to strip the battered wings off and clean the inner wing area.
Front bumper off.
Quick clean.
Now all the primers been flatted down and it’s masking up time.
Wings getting ready for paint on the stand. (Were sanded down prior to paint forgot photos)
Front bumper off.
Quick clean.
Re: Marts Caddy
Now time to get the paint on.
This basically brings us up to date. So today I pulled the van out to inspect the bodywork.
Building up the new wings.
Next stage is getting the caddy lowered. Picked these coilovers up for a great price. But need a good clean!
Springs off and painted
Re: Marts Caddy
Seems like I can’t upload anymore photos on here unless I go Vip on Tapatalk. I’ll get that sorted and carry on with the updates.
Cheers gazza has been over a couple weeks but definitely making progress now.
Marts Caddy
Right gonna try another image hosting site
So pulled the springs off.
Only had two choices of paint to use white or yellow, couldn’t leave them as they were so.
Gave the struts a good wire brushing
In between coats I started stripping the wipers off and panel to access top mount bolts
Years of dirt under there so gave it a clean
Wiper motor removed
To get access to top mount bolts
Cleaned metal tray
Now that’s where we are at the moment!
Cheers for reading.
Wiper motor removed
Cleaned metal tray
Cheers for reading.
