C Chis
Re: Let the build begin
Post by C Chis »
Papa Bear wrote:Ordered a set of the repeaters today, those guys are so helpful!
Awesome!
Matias
Post by Matias »
Chris,
how U remove glued mirror handle? I try this few times in my previous Touran and next I must take change window. For window for dimming mirror.
Sent from my LLD-L31 via Tapatalk
VW Caddy Maxi Life 180 HP
C Chis
Post by C Chis »
Hi, I removed the mirror by twisting it off from the window, then carefully, very, very carefully applied heat from my blowtorch (with a bit of shielding from an old bit metal sheeting I had) onto the small fitting left on the window and then when thought it seemed hot enough I used the pump pliers to twist it off.
Used the meths, the tar remover and the utility knife blade to gently scrape away the residual glue
I’m not recommending it, I removed as I didn’t need a rear view mirror anymore and was looking for something to do I started off filling a stone chip on the passenger side A pillar with paint and it caught my eye so I thought, it’s time that was gone
Bobby_London
Post by Bobby_London »
Im Loving the Carpet Lined bulkhead on the cockpit side!
Iz it, Iz it wicked :!:
C Chis
Post by C Chis »
Cheers! Made a huge difference in looks and noise.
C Chis
Let the build begin
Post by C Chis »
Today’s tweaks to Bleu...
New sidelight LED lamps, a little brighter than the originals Image
And a little earlier...
A wash and brush up...
Even used the 2 bucket method, first time in my life!
And even before that the postie arrived with a little something for the winter!
Just need to salvage a heater matrix when we’re allowed out to play.
C Chis
Let the build begin
Post by C Chis »
Mods still to do :-
1. Finish off the cutting and polishing - waiting on some more product and a new polisher being delivered
2. Headlight tweaks
3. Remap
4. Carpet the sides
5. New front seats
6. Trial fitting of a VW flip emblem reversing camera into a spare barn door(long term project!)
7. Retro retrims for the A pillars
8. New lights for the roof
9. Dukes of Hazard air horns (so ‘70’s)
10. Electric window upgrade
11. Flat bottomed steering wheel, unsure yet which one
12. Cruise control
13. Repair/replace chipped windscreen
N+1. Buy a newer Caddy and start again
Why does the list never get any smaller?
C Chis
Post by C Chis »
After cleaning the wheels on my other car I thought I’d get the hot air gun out and give the Caddy’s scuffed up bumper a wee treat...
Before
And after
So I went on and applied the hot air gun to the rear one too, well chuffed with the results.
And the new touch up paint arrived so I filled in a few of stone chips, tomorrow’s task will be to flatten them and clear coat
C Chis
Let the build begin
Post by C Chis »
Passenger side A pillar boulder chip cleaned, painted, cut back and polished
“Painted”
Tada...
Now to tackle the others! Image
Papa Bear
Post by Papa Bear »
When you fitted your repeaters, was there any foam between the light and the wing?
Fitted mine and they are very loose.
Black
Marmite lover!!!
VCDS
C Chis
Post by C Chis »
Hi, no, mine are reasonably tight. I can move them a bit, but they don’t rattle or anything.
A little bit of double sided tape might help to keep them in place and still allow removal.
Papa Bear
Post by Papa Bear »
Am going to find some single sided foam tape in black, will be enough to tighten them. Am still very happy with them and the service I got from them.
Thank you again
Black
Marmite lover!!!
VCDS
C Chis
Post by C Chis »
Papa Bear wrote:Am going to find some single sided foam tape in black, will be enough to tighten them. Am still very happy with them and the service I got from them.
Thank you again
Ace, I never thought about black foam tape Image
C Chis
Post by C Chis »
After seeing what a bit of hand cutting and polishing could do to my van’s bonnet
I’ve been and bought one of these beauties to cut, polish and seal the whole van and save my old elbows!
That’s tomorrow’s wee job sorted, after an hours Zwift meet-up of course
C Chis
Post by C Chis »
And a little foray into the world of VCDS...
Middle button of my remote now coded to unlock the rear doors and it also locks automatically when closed Image
