Hi All, just joined the group and thinking of getting a 2016 Caddy. The plan being to make it into a mini camper/MTB van. I’ve seen a lot of posts here with suggestions and I’m thinking of the plan below. It allows me to have the camper part but also being able to use it to transport using the full cargo area when necessary. I’d love to hear your thoughts or feedback on it. Please excuse the dodge video!
https://youtu.be/JyS6-qXf6d4
Proposed Camper Van Conversion
- Papa Bear
Re: Proposed Camper Van Conversion
If you had more fold out legs you wouldn’t need the support that folds down with the top, making it lighter and easier to fix and to move.
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
The reason i have the fold out bit is so that i can access the cargo area through the side door when the bed is stored away, I couldn't figure out how to have another fold out leg at that end as i wouldn't have anything to secure it to? Feel free to suggest a solution
Reason: deleted unnecessary quote
- Papa Bear
Do you have a bulkhead?
The top could fold out but keep the legs on the lower bit. Less hinges so less flex
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
Think I've decided not to worry about being able to access the side door when the bed is up, there's a door on both sides so i can just get in the other side (So it would be one single piece, with the leg folding over).
I've added some storage and a flip down table as well.
I hope the actual build goes as smoothly!
https://youtu.be/m37U9iRbdLw
Are you going ahead with this build? I'd be interested to see progress as I might look at doing something similar for occasional mtb rides ending at a pub (sleep in the van afterwards!)
Caddy Maxi Kombi 2012 1.6tdi - subtle mods.
