seat belt colour change?
anyone changed their seatbelts , if so how easy is it cheers ?
- dan@biali
I did mine towards the beginning of my build. Pretty straightforward. B pillar trims off and the lower sill cover popped up to reveal the bolt at the bottom, top bolt is under the plastic cap which you just lever open. You’ll need to disconnect the battery so the airbag system has dissipated any charge before removing.
The seatbelts you can then have changed by trimming companies or do what I did and take the belts to http://www.fdts-seatbelts.co.uk/Index.html who can do it while you wait.
