E8OMB’s Caddy build - 1.9tdi
- Lister79
Re: E8OMB’s Caddy build - 1.9tdi
Great build mate, keep the updates coming .
- Rossy888
Excellent Yes facelift done was curious as someone on the forum had trouble with an older caddy that he facelifted with these lights on the drl side thanks again keep up the great build
- R22LRM
Cracking mods
R22LRM
Mk5 Tfsi powered
Mk5 Tfsi powered
Looking good buddy, keep up the good work
UPDATE: Front end is nearly complete, just waiting on some bits from TPS that will arrive tomorrow including edition 30 side strips and brackets to fit the headlamps.
Here’s some pics of the wings and bonnet on. Rear privacy glass fitted.
Tomorrow headlamps bumper, splitter and mk4 rear bumper to be fitted.
Then off to the workshop for BMM turbo, pd 130 injectors, map and 6 speed gearbox conversion with new DMF etc
Then to finish off early next week it will having the new trim fitted and wiring sorted for the stereo, reversing cameras etc
- Oldgregg
Great build. Is that E-Type a series 2?
Yes 1969 series 2 FHC
Hell of a thread this, It really is going to look fierce. I love the custom interior, although im sure it's costing and arm and a leg its going to be a complete one of a kind. i cant wait to see the rest of the progress
- Oldgregg
Beautiful, Looking to get mine transferred to the 5 speed box soon, always good to see another one.
Looking forward to seeing what your turbo and injectors put out as that’s the same mod as I’m contemplating, are you upgrading the clutch with your new 6 speed box?
Thanks I’ll have more pictures tomorrow hopefully. Yes it’s ran away with it’s self money wise, should be a nice daily though once done. Will be used to do a daily 100 mile commute from Mid Devon to my showroom in Somerset with my Boxer and Rottweiler, hence the need for the 6th gear!!
I’ve used a standard pd150 LUK Dual mass flywheel and clutch and changed the oil in the gearbox. New starter motor, new outer cv joints and new gear cables/linkages.
Should make around the 160bhp mark area i
Would imagine, then I’ll be waiting for the BLS engine to go bang
- Oldgregg
yeah I’ve heard with that setup you can get around 160 plus comfortably some even claim up to 200, that’s why I’m interested to see how yours goes because in the back of my mind I’m also thinking will the BLS go pop haha.
More than likely but it’s an excuse to move on to something better
- Oldgregg
I like your thinking
You have to do more than turbo, injectors and a remap to make the BLS go bang. It can hold 200+ with no problems.
Btw, nice build, looking foward to see the end result
Current built thread: 2013 SWB Caddy 2.0TDI
viewtopic.php?f=13&t=48634
My previous built: 2007 SWB Caddy 1.9TDI
viewtopic.php?f=13&t=39945
Wow, looks great, seats are a wee bit crazy for me but definitely special! Looking forwards to seeing more.
Caddy Maxi Kombi 2012 1.6tdi - subtle mods.
