Touran 2 button window switch
Hi
Does anyone know the parts numbers for a 2 button Touran drivers door card switch and handle??
- Beaker2135
Re: Touran 2 button window switch
Touran door card 2 switch conversion
Touran door grab - 1T2-867-372-D
Switch - 1K3-959-857-C
New plug - 1K0-972-704-A
Wiring guide;
Pin 1 brown and white
Pin 2 lilac and blue
Pin 3 red and white
Pin 4 red and yellow
Wiring guide;
Pin 3 red and white
Thanks mate
I take it I use the new plug with the existing caddy door card wiring??
- Beaker2135
I’m not sure as I haven’t done it I salvaged this info from here a while back
I can’t remember how much wiring is attached to the door cards but I think it based on using the wiring on the Touran card. There is plenty of info on here about this and lots of members have done it
Thank you
I just use the caddy wiring and the standard switch for the the touran two button switch.
Cheers for clearing that up Gary
- Carpmaster
Thanks for the info I'm struggling to do my 2 button switch as on the touran it has 8 wires and I don't no what 4 wires to use
Probably the worst advice ever coming now!
I tried two wires together and then by trial and elimination until one of the windows opened and closed correctly!
Then tried two more wires from the six that where left to until I had both front windows opening only.
I'm amazed if that worked as the door control module uses one reference wire and then switch signals back for each window.
There's also a switch illumination wire which I would recommend you don't short to some random wire.
- Carpmaster
Can you remember what colour wires they was to get them working matePeterpan21 wrote: ↑Sat Dec 17, 2022 11:12 pm Probably the worst advice ever coming now!
@Peterpan21. That’s errr….brave!
I know, like I said worst advice ever. Actually, please don’t try this I was just lucky!the swan fiend wrote: ↑Sun Dec 18, 2022 1:53 pm @Peterpan21. That’s errr….brave!
- Carpmaster
Do you know what wire goes where mate as there is 8 different wires
