Very Stiff Bonnet release cable
Towner11
Post by Towner11 »
As above, my bonnet release cable is really stiff, it’s bloody hard to pull the lever to open it. Any advice on how I go about fixing it? Many thanks
likerofbicycles
Re: Very Stiff Bonnet release cable
Post by likerofbicycles »
Not a helpful reply but I had my garage replace it as part of a service when it snapped on trying to use it. They said it was a pain in the arse to sort out, I'd get it looked at before it goes mate.
xxshepxx
Post by xxshepxx »
New cable mate, you can try spray grease up inside but it will only last so long, it will eventually snap leaving you stuck
Post by Stedlocks »
Have a look on here for the bonnet cable release mod in the how to's....its simple to do, using a couple of cable ties, which stops the plastic gubbins falling apart and leaving you up the creek of brown stuff. :lol:
Towner11
Post by Towner11 »
Cheers all, looks will have to replace the cable then. It has broken the lever by the drivers footwell being so stiff. Done the cable tie trick too
Hi,
@Stedlocks
Can't find the How To ? Bonnet cable release mod ...
Do you have a link by any chance
Ta
Post by Stedlocks »
https://www.caddy2k.com/forum/viewtopic ... od#p314633
Its on page 541 if that doesn't work...
:thumbsup:
I'll try to work it out tomorrow ...
Post by Stedlocks »
Its easy fella....the oblong shaped bit is clipped under the scuttle by the catch.....pop it out, get a couple of cable ties around it, at each end, then pop it back..... Apparently, it has a habit of splitting open, causing much hassle getting the bonnet open, involving going in through the wheel arch liner and fiddling about. Ok if you're a gynaecologist , but I'm not, although I do like to keep my hand in and my ex wifes gynaecologist and her go back a long way etc, etc... :lol:
:thumbsup:
