- Papa Bear
Had a DRL blow yesterday, debating wether to get LED or not
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
@Papa Bear I got some white drls off Ebay, they're not led but I think they look bang on!theure a blue bulb so look good when just stood but a nice white when on I'm sure I posted the link on here somewhere
More to follow
More to follow
- Papa Bear
@ry_vw found it
Ordered
Ordered
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
Gazza31112 they can be coded with VCDS.
- gazza31112
Yea mate due to get some bits coded soon anyway so I can add that one on
- DeanWhit
Sprayed the mesh behind the grill badge.
Sent from my ELE-L29 using Tapatalk
- C Chis
Tint film applied to my rear lights after detailing my daughters car
Nice and quick to apply the film
Before...
After
Before...
After
@C Chis were was that from?got qoutes about £60 to tint rear lights
More to follow
More to follow
- C Chis
[mention]RY_VW [/mention] from eBay, search for “30x120cm Light Smoke Black Tint Film Headlights Tail lights Car Vinyl Wrap New” £3.76, seller is “siranobary” delivery was slow, but film seems to be good quality
I have enough for 1 more light
@C Chis found it thankyou,did you take the lights out or keep them in to apply the film?
More to follow
More to follow
- gazza31112
Finally got my folding mirrors coded and a few other bits, long time coming.
Love the folding mirrors!!!
Number plate light error gone, puddle lights on, MFD digital speedo
Big thanks to claudiu for helping me out, top man!!
Recommended his services to anybody
- C Chis
[mention]RY_VW [/mention] I left them on, easy enough to apply and sealed the edges with a little help from my heat gun
Started changing my Mk4 Caddy headlights to Xenon OEM units.
First step was a right pain - Cutting the wiring loom tape back so that the plugs stretch to the new position on the Xenon units.
Took ages and much swearing - didn't quite cut through any wires !
I'll have to re-wrap when I get some of that Scapa Rayon loom tape stuff - OEM Stylee (thanks TommyZoom and all)
Taking off the bumper wasn't too bad - The hidden screw was OK given the hints on how to find it in the How To
Pops off nicely but I bet it is a bit more trouble going the other way.
Coded in using Docs guide and OBDEleven, and then fitted in headlight units easily enough.
Right Pain #2 - Trying to get the beams aligned.
I had marked out the beam patterns on the garage door with some masking tape.
Changed one headlight at a time so that I could see the original LH alignment vs new RH headlight.
There must be an easy way, but it took me ages to get it almost OK for the RH unit.
Next LH Unit ... Sticks out at the back corner and still never gets to point to the right spot still pointing left a bit too much for my liking, compared to the original units.
I guess I will have to get my garage man to have a go ...
Tomorrow : Get the bumper back on !
...Hopefully
...Hopefully
Installed new Pioneer headunit and wired up a reversing camera. The unit is CarPlay so ran the wire up into my armrest to keep any cables out of view!
Had my new windscreen fitted, with the graduated tint....had to drive to Cambridge, After the original mobile fitter had the wrong one on his van
Its time to book an mot now!
