- tonyhill
^^^ that looks really neat. How does it fix to the van, or does it just rest on top of the doors?
- Sambessey
I got these
Gave them a bit of a clean up
And then fitted them
Theres a series of magnets inside the material which fixes on to the roof.. and then 2 bungee cords and grips which fix to either side of the doortonyhill wrote:^^^ that looks really neat. How does it fix to the van, or does it just rest on top of the doors?
What year is your Caddy? My 2012 has fan jets which are much better than the 3 separate jets. Nice easy upgrade to do!MR JT wrote:Sorted out the clogged water jets.
- MR JT
Its a 2014 highline. Mist jets would be so much better. I've read that golf jets will fit the caddy so might give them a go?
Sent from my SM-G970F using Tapatalk
Thats strange, maybe mine were upgraded by the previous owner. I've been looking for some my TTRS but the fans don't work with the screen angle. Golf/touran/tt/caddy are all the same shape so physically fit in the hole. Probably most the VAG cars use the same ones.
- Rohtang666
My caddy has fan jets, I’ve never changed them. Van is ex fleet direct from BG, 2011/12.
Maybe they were an extra when ordered from VW?
I always thought the fan spray was standard on all vag cars/vans. I have a 2007 caddy and have them on mine.
Fitted mk4 rear lights - fitted touran interior but stuck as too how the seatbelts fit
Started working though the mystery wiring on my 2015 ex GB caddy maxi - successfully removed the Viezu box from the engine bay wiring.
Next jobs -
- chase out the mystery 12v wiring
- work out what the deal is with the battery isolator (and remove?)
Next jobs -
- DeanWhit
Nice little meet this morning. Good chatting to everyone and meeting new people. Looking forward to the next one.
Sent from my ELE-L29 using Tapatalk
The difference a cheap set of alloys make!
Sent from my VOG-L09 using Tapatalk
- james400
Had a play around with my printer 2day and made some can holders for the caddy
- Azz03
@mikenorman apologies mate didn’t see your message for some reason I’m still getting the message about not being able to pm anyone it’s asking for me to contact the administrator I’ve been on here long enough and posted enough so may have to contact to gain more access. I have spotted you on Facebook caddy page mate I’ve not got Facebook but I use the wife’s page for the caddy pages so I’ll drop you a message on there if that’s ok mate
- Papa Bear
@azz03 you are showing as a 5+ member, need to request for 30+ access to pm
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
