I'm trying to understand the internal electronics of the various central locking units on the Caddy.
I've attached 2 screen shots of central locking units from Elsa. One from the rear door and one from the sliding door.
Can anyone explain the difference in the internal switches?
Why does one have a dashed line to the motor? What does it mean?
What type of switch is symbolised by the double lined arrow with a circle?
Any help is much appreciated!
ElsaWin wiring diagram symbols
- tommyzooom
Re: ElsaWin wiring diagram symbols
The bottom one looks like a relay, the motor pulls the bar ( dashed line) to close the 2 circuits.
Not sure about the top one, as it looks similar
Ahhh yes, good shout!
The top one is confusing me more though. The same symbol is use for the contact switches in the door catch.
- Attachments
- 3.JPG (17.83 KiB) Viewed 278 times
- Papa Bear
Is the first one a latching relay?
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
I don't think it would be as the contact switch uses the same symbol and there's no relay in the contact switches.
- Giddy
If you could tell what they are, it might be obvious, but the top one is mechanically operated switch.
Bottom one is motor operated switch.
