upgrade climate control panel
scatman75
Post by scatman75 »
hi has anyone went from prefacelift to facelift climate control panel,is they any hows to on this...
to this
to this
vw-golf-mk6-1.4-tsi-dsg-ac-heater-climate-control-panel-breaking-7n0907426k-1358-p.jpg (31.34 KiB) Viewed 4278 times
from this
from this
scatman75
Re: upgrade climate control panel
Post by scatman75 »
ive got a mk4 dash im putting into my mk3 caddy so any help i very much appreciated...
Ryzar1
Post by Ryzar1 »
I would be interested to know as well
Ryzar1
Post by Ryzar1 »
Mate I would imagine if your fitting a mk4 dash wouldn’t the new climate panel come with
scatman75
Post by scatman75 »
Ryzar1 wrote: Thu Jul 30, 2020 9:54 pm Mate I would imagine if your fitting a mk4 dash wouldn’t the new climate panel come with
yes new climate control panel is with the dash,im just interested in if its been done before,wiring , repinning etc...
tommyzooom
Post by tommyzooom »
Yes. I have...as part of my AC retrofit .
Note the older on is cable driven, whilst the new one uses electric servo motors for the temp flaps etc, so you need to replace the heater box too.
scatman75
Post by scatman75 »
tommyzooom wrote: Fri Jul 31, 2020 12:44 am Yes. I have...as part of my AC retrofit .
hi tommy thanks for giving me at least a glimmerof hope of getting this done,do you know what parts i may need to get it working correctly ,thank you...
VanLife
Post by VanLife »
I've done this but in a slightly different way.
As part of transplanting everything from a 2008 touran into my 2012 Caddy, I kept the climatronic unit from the Caddy as the Touran had the old manual controls.
As mentioned above you need to swap the heater matrix from behind the dash so its a dash out job. For me the wiring was just plug and play. No need to change any pins or anything. Just plug it in and you're away. The climatronic unit is completely a stand alone unit and only needs power to work. The earlier manual controls had a few more wires but these are redundant once you fit the climatronic unit. Nothing to code either.
scatman75
Post by scatman75 »
VanLife wrote: Fri Jul 31, 2020 10:12 am I've done this but in a slightly different way.
cheers vanlife ,i could go grab the climatronic unit tomorrow ,is that all i need ,any sensors etc...
tommyzooom
If you have the panel in your second picture, then you'll need a lot more parts than that,
Like heater box, AC compressor, AC pipes, AC condensor, refrigerant, etc etc
scatman75
Post by scatman75 »
tommyzooom wrote:If you have the panel in your second picture, then you'll need a lot more parts than that,
I have aircon in my caddy,pretty sure it comes standard in Australia,do I need to upgrade my ac as well Tommy...
VanLife
Post by VanLife »
No need to upgrade the AC. You just need the heater matrix unit and the climatronic control panel. Plus a new fascia for your dash.
tommyzooom
No, but the panel in your second pic isn't an AC panel.
The other thing to budget for then is a re-gas
And dash sensors and sunlight sensors etc if your going climatronic
Sent from my moto g(7) power using Tapatalk
@scatman75 are all the quotes absolutely necessary? If you are replying to the previous post, reply will suffice.
scatman75
Post by scatman75 »
Doc wrote:@scatman75 are all the quotes absolutely necessary? If you are replying to the previous post, reply will suffice.
You angry mate cause I used a few Quotes ...
