upgrade climate control panel
Ryzar1
Re: upgrade climate control panel
Post by Ryzar1 »
The bumper I managed to find at grant walker parts the mirrors I got off ebay came from Germany last year, Today’s project is trying to get the fog lights working there was a loom with the globes attached to the bumper but I need the rest of the wiring
scatman75
Post by scatman75 »
whats that bumper off...
Ryzar1
Post by Ryzar1 »
They said it came off a 09 caddy lwb wheelchair model
Ryzar1
Post by Ryzar1 »
Makes a huge difference
scatman75
Post by scatman75 »
My Fleet...
scatman75
Post by scatman75 »
Ok I've got the heater box today,quick question before I start on this job,do I have to do a regas,I've read you can split the box so it's not needed,I'm not sure so need some advice please...Image
scatman75
Post by scatman75 »
Anyone please,I'm about to attack this today ...
VanLife
Post by VanLife »
Don't know if you can split it, I didn't look as I was swapping it over anyway. If you swap it over you will need to regas it.
scatman75
Post by scatman75 »
hi vanlife did you just replace the whole unit and just get a regas...
scatman75
Post by scatman75 »
on an earlier post you said i only needed the heater matrix is this correct...
VanLife
Post by VanLife »
I replaced the whole thing
scatman75
Post by scatman75 »
looks like the easiest way i suppose,ive the dash out lastnight,ten min job , need to remove the cross member to remove the unit out now,im also installing a mk4 dash as well...
Lister79
Post by Lister79 »
Hi, easiest way is to swap everything. Splitting the heater box while still installed and then get it back together right would be an absolute nightmare. Once the dash and cross member are out the actual swap is easy.
scatman75
Post by scatman75 »
so i pulled the heater box apart and discovered no need to remove the full box from my caddy,i just need to replace the front vent part as the original one was manual and the new one is electric,also replaced the heater box harness...
scatman75
Post by scatman75 »
HeaterboxImageImageImageImage
