J_Con
Posts: 607 Joined: Thu Oct 12, 2017 9:52 pm
Post
by J_Con » Sun Sep 06, 2020 2:46 pm
Might give it a go if I'm brave enough! Got a touran console there ready to fit! Loving the work mate vans looking ace! Hope Ed was able to sort you out with your cluster
Sent from my LYA-L09 using Tapatalk
C Chis
Posts: 1685 Joined: Fri Mar 06, 2020 1:13 pm
Post
by C Chis » Sun Sep 06, 2020 2:48 pm
Cheers and thanks for the referral
3D cluster and spare remotes should be here sometime through the week
My VR6 Build Thread and Details can be Found
Here
Papa Bear
Posts: 1882 Joined: Sun Mar 01, 2020 10:44 pm
Post
by Papa Bear » Sun Sep 06, 2020 3:04 pm
Look forward to seeing that fitted
Black
Marmite lover!!!
VCDS
J_Con
Post
by J_Con » Sun Sep 06, 2020 3:05 pm
Will definitely make a big difference! Can't recommend him enough
Papa Bear
Post
by Papa Bear » Sun Sep 06, 2020 3:25 pm
Is that the cluster you showed on page 19?
Black
Marmite lover!!!
VCDS
Lister79
Posts: 2200 Joined: Fri Jan 20, 2017 8:38 pm
Post
by Lister79 » Sun Sep 06, 2020 3:35 pm
Looking good mate, well done.
C Chis
Post
by C Chis » Sun Sep 06, 2020 3:59 pm
[mention]Lister79 [/mention] cheers buddy!
[mention]Papa Bear [/mention] erm... no
that was a highline, red display from a Touran, I’ve had a change of mind/direction... pictures to follow once installed
Here
Papa Bear
Post
by Papa Bear » Sun Sep 06, 2020 4:07 pm
Lol thought so.
Waiting to hear what’s needed and how much before adding to my list
Black
Marmite lover!!!
VCDS
J_Con
Post
by J_Con » Sun Sep 06, 2020 4:10 pm
You won't be disappointed if im assuming correct!
Made such a difference to my van
Papa Bear
Post
by Papa Bear » Sun Sep 06, 2020 4:15 pm
My display is white, no idea what it is known as but as I have an aftermarket stereo, not sure it would be that much better upgrading other than looks.
(Says the guy spending ages putting blue LEDs everywhere)
Black
Marmite lover!!!
VCDS
C Chis
Post
by C Chis » Sun Sep 06, 2020 4:23 pm
Yeah, saw some images of the 3D clusters and for the price difference and the benefit of only having to have the cluster coded once, I thought, might as well! Although it will detract from the red theme I had going...
Hopefully I’ll be able to lower my van early next week while waiting on the cluster being coded.
Here
Papa Bear
Post
by Papa Bear » Sun Sep 06, 2020 4:45 pm
You went red, I’m going blue, anyone going white?
Black
Marmite lover!!!
VCDS
ACalamita
Posts: 80 Joined: Sat Sep 05, 2020 10:09 am
Post
by ACalamita » Mon Sep 07, 2020 12:06 pm
Damn nice build dude!
Just read through (most of it) start to finish
A lot of stuff is on my list too... Have a few VAG breakers nearby which I'm off to raid again!!
Deffo following more updates on this.
C Chis
Post
by C Chis » Mon Sep 07, 2020 12:43 pm
Cheers buddy!
I’m amazed that you’ve taken the time to scroll through my build, much appreciated!
Make your list before heading to the breakers, it’ll help with your spending, trust me on this one, it’ll stop you getting sidetracked and coming home with loads of other stuff
Van’s now off the road for a few days waiting on a couple of improvements
Here
Papa Bear
Post
by Papa Bear » Mon Sep 07, 2020 1:20 pm
I thought it was law to go to scrappy and come back with more than you intended
Black
Marmite lover!!!
VCDS
