MFSW options?
Gibblarrr123
Re: MFSW options?
Post by Gibblarrr123 »
Sorry on further investigation it’s 5k0953569be for the control module, with this being midline on the table I assume it needs replacing with the high line module, does it need to be a specific high line unit without angle sensor or any ? And where’s best to purchase ?
Thanks in advance
Gibblarrr123
Re: MFSW options?
If anyone could help me on this it would not much appreciated, I’ve tried putting details into website posted by spacewalker 4-5 days ago but yet to receive a response.
Thanks in advance
Re: MFSW options?
Hi Gibblarrr123,
You'll first need to work out which MFSW you want to fit, there are many many variations and along with this the requirements for modules and coding will change.
Do you have a MFSW in mind?
Gibblarrr123
Re: MFSW options?
I’ve got the option of a Mk6 Mfsw with Cruise, radio and menu buttons, cruise and multifunction menu is active on the van but can’t activate the steering wheel as if won’t talk due to the module, the wheel does have the acc button but wouldn’t be in use if that’s possible
Re: MFSW options?
That'll be a mk7 wheel, not mk6.
You'll be easiest to opt for the interface module from spacewalker which you can install or have installed on your original steering wheel control module.
Gibblarrr123
Re: MFSW options?
Right no problem, helps me out a lot.
How’s best to order this ? I’ve tried the contact form on the website he’s posted but had not response as of yet ?
Re: MFSW options?
I'm not sure how you've worded your message to him on his site, but if you've told him you wanted his module to fit a mk6 steering wheel, maybe that's why you've not had a reply.
You're best to send facts like part numbers for your steering wheel, the control module in your caddy, etc.
STEVECZ
Re: MFSW options?
Post by STEVECZ »
Hi guys. If i can ask - i have bought xhorse swcm few years ago but now i reinstalled pc and i have lost that file for swcm coding. Would you please be able to share me? It looks like xhorse dont make swcm anymore and forum is not working.
TIA
