Hi,
Looking for clarification on the front anti rollbar bushes, I bought upgraded front bushes a while ago and just got round to fitting them today ( read try fitting them)
I fully expected them to be like the rear where I remove the 2 bolts holding the clamp over the bush, take off the old bush, replace with a new bush and replace the clamp.
When I removed the bolts the bush and clamp seem to be one piece and very reluctant to be separated. I have since had a look on google to read that possibly the bush and clamp are assembled on the arb and crimped together. It also suggested that if the bushes need replaced then the whole arb assembly including bushes and clamps are replaced as one - surely not?
If this is the case do I need to try and separate the clamp from the old bush or can you buy a separate clamp for use with the new upgraded bush.
I have just left the old bushes in place for now until I can hopefully clarify the situation - any help would be appreciated.
Cheers, Dave.
Front Anti Rollbar Bushes
Ex BG 2011 1.6 tdi - colour coded front and rear bumpers, mirror covers. Side windows and front window wind deflectors. Scirocco 18” Interlagos alloys. Spax RSX coilovers, Gaz rears. Touran rear seats with integrated child seats and head protection headrests. Sound deadening/ insulation with Caddy Life headlining, full interior plastics, custom made boot box,bulkhead with load through.
Re: Front Anti Rollbar Bushes
Hi, welcome to the forum.
The front ARB bushes are indeed contained within the clamp and a pig to change.
You will need to drill/grind out the face where the captive nut is pressed into the flat side of the clamp to split it apart. Unfortunately it's not a ten minute job but it is possible with the correct tools.
- sheepy92
Looking at them are the bushes accessible to remove also im looking at changing my front anti roll bar does this require dropping the front subframe it looks awfully tight
Cheers Doc, much appreciated, as you’ll see I registered a while ago but never posted - mainly cos I’ve never had anything constructive to add.
Thanks for clarifying, it always amazes me how manufacturers have the ability to take a simple uncomplicated item and just add an unnecessary level of difficulty in replacing or repairing.
Just following on from what Sheepy said, does this require the subframe to be dropped or can the bushes be slid along the arb from their original position towards the middle of the car/bar and split there ?
TIA
TIA
It's 40 times easier with the subframe out, I can't imagine the headaches of trying to do it in situ.
Okay doke, thanks.
