Hi All,
When parked on a gradient my sliding door won't stay open. I've tried to search but can't seem to find any posts. Is it a simple fix, something simple to purchase?
Thanks in advance.
Sliding Door.....Sliding Shut....
Re: Sliding Door.....Sliding Shut....
Ok so I found out it's the door catch. Can you just buy the plastic bit or do you need the metal holder too?
2K0 843 413 A
2K0 843 413 A
Once you fully pull the sliding door open it should engage with a white plastic clip to keep it open on a reasonable slope.
Over time that clip can (will) wear and indeed possibly break, so depending on the gradient of the slope it can slide shut. That part is an easy DIY task to remove and replace. Doors on my Maxi take a real hammering loading and unloading groups on trips to and from the local ski slopes - so I am on my third set. Thankfully they are not too expensive to replace.
Did you just but the plastic clip or the entire bit?
On my 2012 maxi the part comprises both bits - so the plastic section which is riveted to a metal mount.
The part number was 2K0-843-413-A.
If you have a SWB then you should check whether the part number is different.
- Semster
Could anyone provide the part number for a SWB L&R Doors please? Many thanks in Advance.
They are listed as the same part numbers for SWB and maxi.
Left 2K0-843-413A
Right 2K0-843-414A
7Zap Link
Left 2K0-843-413A
Right 2K0-843-414A
7Zap Link
- Semster
Wow! that site is amazing! thanks for that. Favourited.
I'll get some ordered as I also found out my door doesn't stay open.
