Bicycle mount ideas
- C Chis
Re: Bicycle mount ideas
[mention]bibbycaddy [/mention] hi buddy, they are powerfly ones from amazon. I went for the more robust yellow ones verses the slightly smaller red ones. Been using them most days for the past month, holding up really well!
[mention]C chris [/mention] that’s great thanks look nice and neat aswell
- Evoman
Hi, I’ve just fitted this from a chap on eBay. 3D printed and really sturdy. Available in many colours and fork fitments
Take a look https://www.ebay.co.uk/itm/224123401583
- C Chis
[mention]Splinter [/mention] hi buddy, apologies, missed your post
I use a couple of small d rings on a plate and 2 shortened bungees, like below
The D rings and bungees were from a local hardware shop, toolstation.
The D ring is bolted through the thin ply with large washers behind to spread the load.
Cheers Chris I think this is the route I’m going to take, looks very neat and tidy.
I use Same as above. never let me down
I'm really liking what you've done here, who is the bed fixed in? does it use the same rails as the fork mounts?
@chris-a-owen I used pronged T nuts to bolt the bed to the floor as it splits in half and makes it a lot easier to remove using winged bolts.
I quite like the idea and practicality of a removable fork mount. I’d love a fully recessed mounting system, but realistically I think a removable will be easier to fit and have the best of both worlds.
I also want to be able to sleep in the van too, so it needs to as minimalist as possible!
I used this Fork mount. Found the company on Facebook. I just strap the board in when I need it. (Cream carpet has since been changed )
This is an awesome idea!
where can I find the mounting rails?
[/quote]
[/quote]
- glennj
That looks just the job. I wonder if there’s a 3D model to print your own somewhere, hmmm
Reason: removed most of the photos quoted
2019 Reflex Silver SWB
