Stormtrooper caddy 4 build
- Sag1
Re: Stormtrooper caddy 4 build
Good work dude. Scratch came up really well!
2106 Caddy Life 1.4 TSI | Wheelchair Driver | My Instagram
- Caddyluv
Yes bit of 2000 grit and rotary polisher only took 5 mins. Quite bad. But sorted.
Is it really that easy ( I say easy) to remove deep scratches. I have a few on the side and a couple along the back of mine. Is there a certain point at which this method won't work?
Also could you reccomend a rotary polisher for a beginner. Looking to get into trying a proper polish and scratch removal.
- Caddyluv
@pepsi
Well yeah there is a point... your go through the clear coat then your need to respray it. But if there light then yeah a bit of 2000 grit a little sanding pad and a bit of experience.
Rotary tend to cut quicker but honestly they can be a little dangerous in new hands so I would recommend a Vertool DA doesn’t cut as quick but does a good job. Your need the correct pads and compound..... it starts getting expensive
https://rover.ebay.com/rover/0/0/0?mpre ... 4693030837
- Caddyluv
Got a nail
- Caddyluv
So the vans back to normal today got a new tyre fitted. Would like to thank ATS in cheriton for driving the van into an upslope and ripping the bottom of the bumper along the concrete so after I was telling the guy to be careful and about the side skirts and it’s low...they clearly didn’t listen so £50 reduction on the tyre so it wasn’t to sad. I was just worried it could have cracked the custom bumper but thankfully all looks ok. But it was hammering it down so it was a quick look.
- Caddyluv
Little service today.
Also glow plugs. Had a engine management light pop up. It was plug 1. So replaced them all.
All done running smooth.
- Azz03
Caddyluv is your rear number plate plinth an edition 30 or have you custom made that? As it doesn’t look like a painted line
- Caddyluv
@azz03. No mate it’s been custom made.
Then primed, preped and painted. Use thin pinstripe tape to do the black and white paint.
- Azz03
Caddyluv I did think you’d put a small rebate on the plinth to give the idea of the separate lip looks top notch mate. I have searched loads but they don’t do the edition30 rear plinth do they only the side strips?
- Caddyluv
Yes mate. That’s why we made one, there isn’t one out there, Thank you I think it’s a nice touch.
- Azz03
Caddyluv you can’t beat the mods that are hand made as it’s unique cheers for the reply
- james400
Nice and fresh ready for the winter mate
- Caddyluv
Just needs a wash now. But with this weather you think what’s the point.
- Caddyluv
Vans so dirty needs a good clean. But doing these country lanes you think why bother.
