Giddy
Post by Giddy »
Spent a best part of the day fitting CSR spoiler. What a pain in the arse to line everything up properly. Hopefully I don't have to do anything similar any time soon ImageImageImage
Can't wait to see it in a daylight now Image
Caddy 4, Highline, 1.4 TSI
Instagram: @giddywagen
Build thread >>> here <<<
Lister79
Post by Lister79 »
Very cool mate, top work as always.
brooneye
Post by brooneye »
Looks good buddy
Giddy
Post by Giddy »
Thanks lads Image
Couple more daylight shots. Very pleased how it's turned outImage
Sag1
Post by Sag1 »
Looks great dude, really liking that!
2106 Caddy Life 1.4 TSI | Wheelchair Driver | My Instagram
Caddy Dan123
Post by Caddy Dan123 »
Smart as buddy where did you take live for cigarette lighter in the rear of the van mate and is that permanently live?
Giddy
Post by Giddy »
Thanks mate. I've added an extra feed from the fuse box. It is permanent live.
How to is in the link https://www.caddy2k.com/forum/viewtopic ... 22&t=33096
Also, if you need a plug and play solution, you can drop @tommyzooom a message, I'm sure he can make you a loom.
Rigguz
Post by Rigguz »
Such a nice van! Colour is amazing!
With your spoiler did you just bond it on, it or did you use any fixings? Looks spot on!!
Giddy
Post by Giddy »
Thanks mate. No fixings, some double sided tape for the initial fit and windscreen bond to keep it in place.
Giddy
Post by Giddy »
Only a small upgrade, but these side moulding are a proper patience testers ImageImageImage
mijkie
Post by mijkie »
Nice !
Do you have the partnumbers ?
Verzonden vanaf mijn iPad met Tapatalk
Giddy
Post by Giddy »
Yes mate, all of them are listed here https://www.caddy2k.com/forum/viewtopic ... 22&t=21017
mijkie
Post by mijkie »
Thnx !!
BenXCIV
Post by BenXCIV »
Is there a technique to removing the side mouldings, or do they just come off easily with a bit of manual persuasion & heat?
Giddy
Post by Giddy »
I'd say the easiest is to cut through the tape at one end using a braided fishing line or super strong thread. Then start pulling up that end slowly while heating it up. The heat helps a lot, as the double sided tape becomes softer/gooey and comes off a lot easier. Don't go crazy with the heat gun if it's not a temperature adjustable one :)
Then just a matter of cleaning up the tape residue with something like "tar remover". That's how I did it.
