Favourite VCDS 2K Codings/Adaptions
- Andrejm
Re: Favourite VCDS 2K Codings/Adaptions
I got :
-cornering lights
-seat belt warning off
-DRL via separate lights
-hill hold assist off
-comfort turn signal to 5 times
-cornering lights
- Semster
anyone know how to have rear lights on at the same time as dry. basically rears on constant ?
I got my pq composition media today. Very happy. Got it very cheap on eBay. It’s nice to have lots of adaptions to play with.
Unlocking cp and functions this week. Also having a go at enabling car status menu like mbq. And latest mib2.5 menu layout and themes. I’ll keep you posted.
Just ordered vcds from Ross tech need to learn how to use it now lol
- Semster
Best tip. Write down notes for what you change. (Software does this in logs but it’s not as easy to follow)R4Z4_9ts wrote:Just ordered vcds from Ross tech need to learn how to use it now lol
First step: do a full auto scan. As well as a full adaption map.
if you have limited vin don’t connect to another car unless you want to spend a vin.
- Papa Bear
When done an auto scan, save it
Also you can connect to other cars to diagnose without using a vin license, if you make changes that requires a license to be used it does ask you if you are sure you want to
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
- anoneamus
Thanks I got the unlimited vin so should be alright there manSemster wrote: Best tip. Write down notes for what you change. (Software does this in logs but it’s not as easy to follow)
- Beaker2135
Any body seen this or any other Easter Eggs?
I’ve stolen this from VCDS Users UK on Facebook but I made me smile
“Dont know if I'm the last person to notice this. But I discovered this little Easter Egg while code scanning an Audi today, I've never noticed this in about 8 years of using VCDS. Flux Capacitor module fitted properly confused me for a while. I later found out its to do with the time and date being set wrong on the laptop. So the car is ... From the future ”
I've never seen that before.
Gotta question why someone would not have the time and date set correctly on their laptop, that'd but the life out of me.
- Beaker2135
Kind of makes me want to do it though to check it out
- Dickyboy82
Has anyone got a part number for the Flux Capacitor?
I don't, I've asked Ross-tech to supply information on who has stolen my design.
If anyone knew it, it would have been you Doc.
Well the patent for the Flux capacitor is in my name.
